Old 08-02-2009, 10:56 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
What does the titanium oxide w/s block?
I know its for UV rays, and I have heard that people have to use external EZ Pass transponders, but will a GPS unit acquire satellites if the antenna is internal or mounted under the windshield ??
I have searched the Mod section and read conflicting accounts, thanks.
Old 08-02-2009, 11:23 AM
redlightningsvx's Avatar
Collision Refinishing Tech
Re: What does the titanium oxide w/s block?
It doesn't allow uv rays to fade the dash out. You'll wonder why a 15 yr old car doesn't have a dry, cracked dash like most older cars.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 08-02-2009, 11:44 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
What im asking really is, does the windshield block satellite signals?
Old 08-02-2009, 11:47 AM
I think it does/doesn't. Some people can get GPS to work but it may lag.
Seth
Past subies:
Other toys:
Old 08-02-2009, 11:56 AM
I have Garmin Street Pilot 330 and yes it does have trouble acquiring satellite in the SVX, but once they are acquired it seems to hold onto them through out the trip. What I usually do is open the sunroof and hold it out there for a few minutes till it acquires the satellites, then just pop it back onto dash and your ready to go. If I stop for gas and it turns off, or if I go through a long tunnel I may have to do the acquire thing again, but I can definitely verify that it does work.
You could also get the extension antenna and run it to the back, that should make it work better.
Old 08-02-2009, 12:20 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Excellent, thank you guys.
Old 08-02-2009, 12:32 PM
Francis Francis is offline
my gps antenna is right under the dash and never had a problem with it , never lags . its a kenwood DNX512EX
Claret 92 Ls-l R.I.P - 24XXXX - kms "april 2008"
rest in pieces
Ebony black 92 Ls-l Alive - 25XXXX - Quick change, Powermod , Alternator Mod , audiobahn 1300 watt ach ,exile 800 watt peak, jackhammer 12" 300 watt rms, polkaudio 6 1/2 compoment. kenwood dvd\nav . radar detector.small car lens and grill
Old 08-02-2009, 12:54 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Cool Re: What does the titanium oxide w/s block?
I,ve had my Navman ICN630 working for over 5 years - positioned in front of the guages, without the antenna swung out.....works just fine.
Old 08-02-2009, 01:06 PM
svxash's Avatar
svxash svxash is offline
Do all the windshields have this? What about the bronze windshields with GPS?
1997 Boudreaux LSi
1994 SVX LSi(SOLD)
Kool Blue air filter, 4500k HID's, airbox mod, Hella horns, WRX 6 disc stereo, Infinity Reference and Clarion Pro Audio speakers, Infinity basslink sub, ECUtune Stage 1v5, ECUtune TCU, Power mode mod, Mad muffler mod v1.3
Old 08-02-2009, 01:40 PM
Mephis Mephis is offline
My magellan unit has never had the 1st problem in my SVX.
Old 08-02-2009, 01:51 PM
LarryIII LarryIII is offline
Chris,
I have used our GPS (Garmin Nuvi #350) with much sucess in our SVXes.
I do not attach it to the windshield. I put it on the console under the lowered parking brake handle. It tells me when to turn........or as NUVI says, when she doesn't like the way that I choose.....RECALCULATING!!!!
Good Luck.
Larry III & The Beautiful Naviguesser
'19 Tungsten Pearl Outback 3.6R Ltd...."AISHA"
'08 Harvest Gold Outback 3.0L. L. L. Bean...."AIJOU"
'07 Gray Diamond Pearl Outback XT Ltd..."AH SO"
'05 White Pearl & Silver BAJA Turbo..."AH HA"
'97 Bordeaux Pearl SVX LSi..."SUBYDOO"
'94 White Pearl SVX LSi..."PEARLY"
'92 White Pearl SVX LSL w/touring pkg..."SVXY"
'92 Teal SVX LSL w/touring pkg..."ALCYONE"
'96 Polo Green LSi ... "MIDORI"
'00 Black Dodge VIPER RT-10... "VINNIE"
Engineers do it with precision.
English teachers are novel lovers.
Home: larrysingeriii@comcast.net
SVX FEVER, CATCH IT AT A MEET NEAR YOU !!
Old 08-02-2009, 02:23 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Excellent! Thank you guys for the responses. I won a new, sealed in box Nextar M3-02 for $36 . Granted its not exactly top o' dee line, but it will serve its purpose well for 36 clams.
Funny, here in CA its actually illegal to use the windshield mount, or to have ANYTHING attached to any windows on the car. Hopefully soon CA will break off into the pacific and end the communist regime here.
Old 08-02-2009, 05:07 PM
kwren's Avatar
kwren kwren is offline
My Magellan unit has some problems but I work it out if I can't get enough "green bars" to make it function, I can open the sun roof and hold it up till I get the satilites going, put it back in it's dash holder, and then all is good. Getting it started apparently takes more that just thew operating part. I have a bronze windshield.
See attachment
Keith
Old 08-02-2009, 05:17 PM
It also helps to block the governmant mind control radio waves...
No need to wear your tin foil hat while driving the SVX
Old 08-02-2009, 05:28 PM
kwren's Avatar
