Old 06-21-2009, 06:17 PM
jamhamm jamhamm is offline
ac questions
general ac question - blow ambient temp so the system is broken ... low coolant, leak, whatever...
car on, ac on max - compressor flips on and off... about 3 second intervals
on off on off on off
jumpered the low pressure sensor - compressor clicks on and stays on... pressure reading falls falls falls...
its about 90 outside and the pressure went all the way down to about 20... so she's low on r134a... got it
but with the compressor forced on [jumper] as i open the coolant, the hoses get tight and the pressure jumps and spikes the gauge...
so... when the can is open, no coolant is flowing into the system?
any ideas?
ive recharged many a ac system - when the compressor is on it usually pulls the coolant in
also i cant hear the tell tell hiss of coolant leaving the canister
Old 06-22-2009, 07:29 PM
NiftySVX NiftySVX is offline
Re: ac questions
If the low side goes low then yes it could mean there is low refrigerant volume. It could also mean there is a restriction in the system, depending on what the high side is running. What are the values of the high side?
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
Old 06-23-2009, 09:39 PM
kwren's Avatar
kwren kwren is offline
Re: ac questions
Probably lo on refrigerant but not always a good idea to bypass a sensor and run it. If has a leak can suck air with moisture in the system. Best to put the gauge on it and easily see what it is doing.
Keith
