Old 06-02-2009, 09:29 PM
gbianchi gbianchi is offline
Question Please confirm
Our stock SVX rear diff is unique to itself, so if its toast you need another SVX rear diff to replace it?? Are there repair parts for sale if you wanted to go that route? Sorry if this has been covered already I may just have a problem in this area and am wondering what the options are, thanks..............G
03 Baja. 05 Baja turbo
92legacywagon"snow"
94legacywagon"whinny"
84Brat"huey"
92svx"samantha".pearl
92svx"sabastian"4.44 silver
92svx"sabrina".ebony
06 Subaru legacy gt limited.
Old 06-02-2009, 09:40 PM
newkid17's Avatar
newkid17 newkid17 is offline
Send a message via AIM to newkid17 Send a message via Yahoo to newkid17
Re: Please confirm
yes our rear diff. is 3.545 gear ratio with a visicious LSD in it. you would need one out of an SVX. or you could do the 4.11 or 4.44 swap in it, meaning changing the front and rear diffs. to that ratio.
do you know what is wrong with your rear diff.?
Old 06-03-2009, 08:38 AM
Re: Please confirm
Not at the present, all I know is there is alot of noise coming from the rear ofthe car. I have read about wheel bearing trouble alot, is there a good way to tell what is making all the racket. Yesterday after a drive the rear diff was warm and the wheel hubs were not??? Thanks for the reply....G
92legacywagon"snow"
84Brat"huey"
Old 06-03-2009, 11:59 AM
NiftySVX NiftySVX is offline
Re: Please confirm
The rear diff should be a little warm to the touch due to the shearing of the fluid which creates some heat. I would get the car off the wheels and get all 4 rolling at 20 or so, then you can usually hear the noise of the bearing if you put your head near the wheel(s)
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
Old 06-03-2009, 06:00 PM
svxpert svxpert is offline
Re: Please confirm
chances are, unless you have no gear lube in the rear diff, your diff is fine. havent heard of one going out before.
Liberalism is a disease. When you can stare at facts and ignore them anyway, you have it.
Old 06-04-2009, 05:42 PM
Re: Please confirm
Thanks again guys, have checked gear oil and was/is fine I am hoping its not the diff, it would be a 1st in my 35yrs of car ownership, do SVX wheel bearing start growling at low speeds and get somewhat quieter at hyway speeds? I appreciate any and all info on this topic and hopefully it can help someone else also........G
92legacywagon"snow"
84Brat"huey"
Old 06-04-2009, 08:57 PM
Re: Please confirm
It is hard to describe what a bearing failure sounds like because sometimes they are loudest at 40 mph and quieter at 70 or sometimes they make a slight noise at 10 and are deafening at highway speeds. The only time I have personally seen a diff go bad on a subaru is because the seals failed and it leaked the oil out, so if it was still full you're probably ok.
Old 06-05-2009, 07:13 PM
Re: Please confirm
Thanks again, for the info I'll figure it out in time...............G
92legacywagon"snow"
84Brat"huey"
Old 06-05-2009, 07:58 PM
dennyo dennyo is offline
Re: Please confirm
my own experience with rear bearings is, at lower speeds it sounds louder, and make less noise at higher speeds.by the time i got around to changing mine it sounded like a helicopter was following me around town
Old 06-05-2009, 08:34 PM
Re: Please confirm
O K sounds about right, I have only had a really bad bearing once.........long ago 78sube wagon it fell apart after removal, the bearing not the car !!!?thanks..........G
92legacywagon"snow"
84Brat"huey"
