Old 03-30-2008, 07:20 PM
Originally Posted by svxAL View Post
I got my car to the tranny shop today and they say that the overdrive is kicking in and out. they say it can be driven like that and sespect it to be my mafs. so I took it off and cleaned it with carb spray.(throttle body clean as well) and put a new cone filter on so everything would stay clean. same problem any clues on what to do if i put it in 3 it drives perfect. Is there any way i can disconnect the overdrive? please help?
thanks- Aaron
Aaron, are you sure they said the mafs?
Because it is more likely to be the TPS [throttle Position Sensor] or a faulty atf temp sensor.
Or even it could be the transmission computer.
For most people overdrive will mean 4 Range. Just to clarify, do these guys actually mean the car is not locking up in top gear? Or that the car is shifting back to 3 by itself??
Old 03-30-2008, 09:17 PM
svxAL's Avatar
svxAL svxAL is offline
more windows then a minivan..
the car will be in the D position and when im going from 35 to 68 it will etheir jump up 250 rpms or drop down 250 rpms continuously i pulled the codes from the tcu and only could get a code 33 but that was from the previous codes I tried to delete this by the blue wire thing i read about the also tried to touch the battery cables but the code stays. I also have a code 32 for an oxygen sensor the the ecu gives me i t didnt even clear that ethier so i dunno what to do now. PLEASE HELP!!
thanks Aaron
*1994 5 speed, Barcelona Red W/ Black ebony pearl top FWD*murrano wheels,lowered with motorsports springs drilled and slotted rotors 20% tint,swapped in leather seats,full exhaust cat delete,15 min mod, red F&R energy bushings
Old 03-30-2008, 09:42 PM
JLHollowX13's Avatar
JLHollowX13 JLHollowX13 is offline
Send a message via AIM to JLHollowX13
if the rpms are dropping and raising as you give it gas/let off on the gas that sounds like the torqe converter to me. it sounds like its locking and unlocking.
Old 03-30-2008, 09:58 PM
svxAL's Avatar
well even if it was the why when i put it in 3 position i dont have a problem at all whatsoever
Old 03-30-2008, 10:06 PM
yeah, thats a good question, i know mine jumps rpms in D, i cant remember if i does in 3 although im in 3 all the time, except on the highway....
Old 03-30-2008, 11:53 PM
thanks Aaron
You have already received the help you require as per previous post:-
Originally Posted by Trevor View Post
The speed sensor is obviously a logical suspect item. On the basis of hard evidence, you must now place it at the very top of your list.
TCU codes 32 & 33 cover speed sensors 1 & 2.
Old 03-31-2008, 02:38 AM
If it still holds that code it still "sees" that problem. Follow Trevor's advice. Fix the speed sensor problem.
If you do both the code should go away and the lock/unlock problem.
PS
BTW when in 3 range the gearbox does not lock up. That's why you don't hear or notice the fault in 3. It only applies to D4 range, that is, to overdrive. It's a feature to reduce fuel consumption at steady speed.
