Old 02-29-2008, 10:56 PM
Octanerush Octanerush is offline
help with lights
none of my parking/licenseplate lights work but the turn signals/hazard lights work
did a quick check on the fuses under the hood didn't see anything that was out...
anyone have this problem before? or is there another spot where fuses are hidden.
also none of the bulbs are out
[M]i[K]E[Y]
Old 02-29-2008, 11:12 PM
fuse box beside the dead pedal
blk 92' LSL w/ average mods
Old 03-01-2008, 10:37 PM
It's Just Eric's Avatar
Missing in action
try testing your parking light switch...
R.I.P Cool Signature.
Old 03-03-2008, 03:35 AM
kwren's Avatar
kwren kwren is offline
Fuse is 10 amp...
[M]i[K]E[Y]
10 amp located left side of engine compartment and looking at the fuses doesn't always determine if it is good or bad. I would find the fuse 10 amp remove it and test it with an ohm meter or with a new 10 amp fuse.
If the fuse is blown, might just be a reason it is blown. You will know when you replace it!
Old 03-03-2008, 03:41 AM
kwren's Avatar
Different fuse for turn indicators.
The turn indicators take a different fuse so they can work while the parking/license plate lights won't!
Good luck
Keith
Old 03-04-2008, 06:08 PM
SVXdc's Avatar
SVXdc SVXdc is offline
Radio wiring harness guru
Ditto that. The switch must be connected and functioning (even when turned "off") in order for the knob on the turn signal stalk to activate the parking lights.
Even if the parking light switch works (to turn on the parking lights without the key), if the "off" side of the contacts or wire connection has gone bad, then the lights won't turn on with the headlights knob.
David C.
