Old 11-30-2007, 11:04 PM
svxman07's Avatar
svxman07 svxman07 is offline
Send a message via AIM to svxman07
svx ram air?
i was just curious do you know how hard it would be to make the svx ram air. if i bought a svx fiberglass hood with the wrx scoop made in it, could i buy the stuff from a sti to make it ram air? how does that work out. does the sti airbox fit the back of the sti throttle boddies, and does the svx maf sensor plug in to the airbox or how would that work? I have no clue if someone else has done it or not i was just wanting to do it to mine later so it would be better air flow than a cold air intake
Old 12-01-2007, 06:29 AM
ridered777's Avatar
Finally HAS a 3rd pedal!!
As far as using STi parts, I don't think they will help you. As I understand it, the STi, along with all the other WRX's, use the scoop to cool off the top mounted inter coolers Subarus are famous for. If this is the case, it would be pointless to feed the intake after that, because not only would the air have lost most of its velocity, but it would also be warm air.
You're best bet at ram air is through the front somehow. This is due to the clearance of the hood vs the intake manifold, there's not much room, so the air would become heated.
There are several threads detailing a few of the ram air ideas. Most are WIP, but will give you a good idea of where to start.
-Craig
Old 12-01-2007, 07:54 AM
Here's the one I made for the racer. Linky
It's not real practical for a street car. Bill "SVXride" also made one for his racecar.
Old 12-01-2007, 08:24 AM
sicksubie's Avatar
xxtuning did a 'top mount" ram air for their eg33 impreza. Check out their website for pics of it (NASIOC too)
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 12-01-2007, 09:33 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
FYI, I really like the one Dave did for the "RaceCar"
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 12-01-2007, 09:58 PM
Ricochet's Avatar
Ricochet Ricochet is offline
I brought some ham.
You could cut a hole in the bottom of the splash guard under the passenger side and throw a screen over it.
Brian
Old 12-01-2007, 10:26 PM
SVXRide's Avatar
Been there, done that...it's actually not very efficient due to the air flow in the region. It does work fine if you're putting a trans cooler in the area
-Bill
Old 12-02-2007, 07:52 AM
-Bill
Thanks Bill, just for that I'll give you one free rain suit photo omission.
Old 12-02-2007, 05:27 PM
SVXRide's Avatar
You're a Prince, you know!
-Bill
Old 12-02-2007, 09:10 PM
SUBBYRU89's Avatar
SUBBYRU89 SUBBYRU89 is offline
Siren of the Pleiades
Send a message via AIM to SUBBYRU89
You mean this photo?
14.708 in the 1/4 mile pre-KillerWail
'89 XT6 Pearl White~JuiceBox (Project)
'92 SVX BoverP~Peej (Down for the moment) 1st Stage II trans installed by AWD,15 & 20 min mods,...
Old 12-03-2007, 07:08 AM
SVXRide's Avatar
[QUOTE=SUBBYRU89;512515]You mean this photo?
and Melis gets the QB with a brutal blindside hit
-Bill
