Old 03-17-2007, 01:09 AM
L.O.R.D. SVX's Avatar
L.O.R.D. SVX L.O.R.D. SVX is offline
Rubbing, gnarling sound... and it ain't the tires.
Sounds something like the driver side front tire rubbing something, but pulsing pattern (kinda like tire with a bubble). But, I changed all my tires because of this sound. Tada, nothing happened. Sound is still there. I can also slightly feel it on the steering wheel. One guy said it could be my front wheel bearings . Another said it could be the brake disc is off balance or the shield is rubbing. If I can fix this, I would rather do it. Could someone point me in the right direction please .
Old 03-17-2007, 01:36 AM
It sounds like brakes. I would guess that the brake shoe is worn or has a problem. If you take the wheel off, you can look at it and maybe decide what the problem is.
Old 03-17-2007, 08:23 AM
curly2k3's Avatar
curly2k3 curly2k3 is offline
Own'eded
Send a message via AIM to curly2k3 Send a message via MSN to curly2k3
definatly sounds like brakes, either warped rotors or misworn pads.
98 Impreza Wago-O-Doom & Datsun Roadsters
Old 03-17-2007, 12:09 PM
Or maybe a broken part which is rubbing.
Old 03-18-2007, 05:54 PM
Right on, thanks for the thoughts. When I actually have time to go down under, I will check it out. It sure sounds alot better than a worn front wheel bearing. How's this, this alignment dude was gonna charge me $1300 just to change the driver side wheel bearing. Then he said if the hub is all bust, that's another whatever bills on top of the first quote, I only laughed. I would do it myself if that's the case, I'm just too lazy so I figured ask. Well thanks again.
Old 03-20-2007, 08:37 AM
snoryda28 snoryda28 is offline
Thats crazy the most that he should charge you for instillation is 200 and thats kinda steep...i just called all of the garages around here to get a price and only one was over that he was trying to get 350..and thats rear
Old 03-24-2007, 04:04 PM
Yeah, I guess he figured it's some kind of "RARE" car, that he could just jack the price up .
Old 03-24-2007, 06:05 PM
haha exactly
