Old 03-06-2007, 05:28 PM
joburnet joburnet is offline
Fluids Q
I did a search but did not find much information on this. What fluids are recommended for the SVX? I just bought mine and I plan on replacing pretty much all the fluids with synthitics, especially the motor oil, trans fluid, and diffs.
Old 03-08-2007, 12:23 PM
dmnknightomega6 dmnknightomega6 is offline
Be careful on the Power steering Fluid. Its Dextron 3 ATF, Not PS fluid. I made that error
Old 03-08-2007, 12:55 PM
Good to know. I got the owners manual since I posted that question and that has all the info I need.
Old 03-08-2007, 04:41 PM
angrydan angrydan is offline
I recommend using the ATE Super Blue brake fluid if you plan on changing that
Dan Taney
1996 Subaru SVX LSi (Red)
2019 Subaru WRX LTD
Old 03-08-2007, 04:58 PM
It doesn't hurt to replace the brake fluid if you don't know when it was done last.
Old 03-08-2007, 11:04 PM
sekler sekler is offline
damn mechanic added 200ml of PS fluid today because the level was a lil low at my oil change.
can it really damage anything ?
Old 03-09-2007, 06:55 AM
I'm not sure if it will damage anything with just a little PS fluid added or not. One thing I did to prevent this from happening was putting a label that said "ATF ONLY" over the cap.
Maybe its time to break out the ol' turkey baster and get your fluid out
Old 03-09-2007, 08:15 AM
dcarrb dcarrb is offline
Factory spec is for Dexron ATF, but "power steering fluid" isn't going to hurt anything unless the bottle is specifically marked NOT FOR USE IN SUBARUS, and I doubt there's anything on the market with such a caution.
dcb
Old 03-09-2007, 09:33 AM
That is why I do all of the fluid changes and maintenance work on mine unless it is a more complicated issue.
