Old 02-26-2007, 06:18 PM
Shadow_Myst Shadow_Myst is offline
Head light problems
I had a problem when my alternator went out my headlights stopped functioning, the switch still operates for the fog lights so I don't quite know what the problem was.
thx
-=SM
Old 02-26-2007, 06:56 PM
DarknessofDeath's Avatar
Inhabitant of Darkness
fuse maybe?
Old 02-26-2007, 07:04 PM
umm no
nope checked every fuse I could think of.. all good.
-=SM
Old 02-26-2007, 07:12 PM
i'm not sure about this one, but the relays?
is it just the headlights that are gone?
do the high beams work?
checked the bulbs..........
Old 02-26-2007, 07:48 PM
well.. maybe
the two bulbs on the left side I know are fine, and the high beams don't work either, does this point to the relay?
-=SM
Old 02-26-2007, 07:54 PM
-=SM
The two on the left are fine? Do they work, or how do you know they are fine? I would check the bulbs first and then if they are good, check the relay.
Old 02-26-2007, 08:00 PM
fillaments
the fillaments are good, how do u check the relay?
-=SM
Old 02-27-2007, 07:46 AM
angrydan angrydan is offline
They are all under the hood of the car right above the battery. The relay layout is printed on the cover.
Usually, I pull one with the same amp. rating from another system I know works and swap it with the suspect one. The amp. rating should be printed on the top or side of the relay (I don't quite remember which).
If it works, then the relay was your problem. If it doesn't, swap it back and keep digging. Just from my own experience, whenever I have had headlight problems, it always ends up being the relay(s).
Good luck!!
Dan Taney
1996 Subaru SVX LSi (Red)
2019 Subaru WRX LTD
Old 06-01-2007, 09:29 PM
Another open ended thread. Was a solution reached?
