Old 02-23-2007, 01:23 PM
davew833 davew833 is offline
Removing windshield?
Has anyone removed an SVX windshield successfully and how hard is it? Is it something I should attempt or get a glass shop to do it?
davew833@yahoo.com
Former 6-time SVX owner
Old 02-23-2007, 06:02 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Yes I've removed a windshield successfully, no I wouldn't attempt it. Took a good 2-3 hours of constant work for two of us. Windshied removal is easy but removing the windshield and the needed gasket (can't buy one) isn't so easy. If you're removing it from a non junk car you'll want to take the dash out and the front cowl out or your piano wire will cut it to shreds. A shop will charge a decent amount with no promises they won't break the glass or ruin the gasket.
Old 02-23-2007, 06:07 PM
Originally Posted by benebob
... but removing the windshield and the needed gasket (can't buy one) isn't so easy.
Glass is available, but the gaskets are not?
Old 02-23-2007, 07:04 PM
benebob's Avatar
It is a one piece system (techinally no gasket is needed as its already fused to the windshield like a fair number of cars sold today, hence there is no part number. A good windshield guy can "make" a gasket but it won't look 100% and will eventually have leaking issues since it isn't a one piece design.
Old 02-24-2007, 12:39 PM
...or your piano wire will cut it to shreds...
Yeah, it was a pain, if I had to do it again, I would try not to...
Use shifter cable from a bicycle shop, it is fairly strong and easier to find, probably cheaper too.
Old 02-26-2007, 09:21 PM
svxcuseme's Avatar
svxcuseme svxcuseme is offline
5 speed 4 sure
Does the dash really have to come out? Looks as though you could just remove the pillar molding on the inside.
Old 02-26-2007, 09:27 PM
It can stay in, but what Ben was referencing is that we ripped up the top of it with the back and forth of the cable.
Old 02-27-2007, 08:48 AM
svxcuseme's Avatar
5 speed 4 sure
Right, so maybe we could tape something in place to protect the dash to avoid damaging / removing it? Maybe I'll try when I get around to it. I'll definately advise if it works.
Old 02-28-2007, 06:53 AM
benebob's Avatar
Remember piano wire is sharp as sharp can be. It'll cut through anything you'd put there. You need the friction to move as you actually cut and melt the glue as you move. It doesn't need to come out but if its your parts car that you're saving the dash from it should.
Old 06-01-2007, 09:34 PM
You must be extra careful with the windshield as it's more fragile than the rest of the windows in the car. Just getting the initial hole through the adhesive is difficult and caused us to lose a windshield we were trying to save.
Old 06-01-2007, 09:41 PM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
I have a local glass shop remove all mine for me and it takes him about a half hour and costs me $40 bucks. You might want to call around a little before attempting it yourself.
Old 06-01-2007, 10:03 PM
That sounds like a good tip. Especially if they would put it in another one that you need the glass in.
