Old 02-10-2007, 10:13 PM
Hop Hop is offline
Classic SVX
power steering
I have a 92 svx that has a slight shudder while doing slow tight turns. High speed is good, around town is good, fluid looks good. It happens when I'm turning into a parking spot, right or left. I haven't noticed it backing up. Also, the more I drive the car, the less noticeable it is. Sometimes I leave the car sit for a week or two. Then it's really obvious.
Greg
Old 02-10-2007, 10:21 PM
Greg
This could very well be a case of air in the fluid, as a result of a leaking O ring, located at the base of the fluid reservoir. Check the how too documents, as the fault is well documented and is a cheap and easy fix.
Old 02-10-2007, 10:40 PM
Hop Hop is offline
Classic SVX
Got the procedure. the car is going into the garage for a timing chain next week. I'll try it then.
Thanks. Greg
Old 02-10-2007, 11:12 PM
Manarius's Avatar
Manarius Manarius is offline
I smell Torquebind, not power steering problems.
-Jason
-Obi Wan Kenobi
Old 02-10-2007, 11:38 PM
Thanks. Greg
No chain, a belt.
Old 02-11-2007, 02:01 AM
bcpianoman bcpianoman is offline
Where is the shudder?
Greg
Does it feel like the shudder is just in the steering or does it feel like it's in the drive train? If it's just in the steering, it sounds like it could be a simple drive (or serpentine) belt tension problem.
Old 02-11-2007, 09:22 AM
Hop Hop is offline
Classic SVX
It feels like it's in the steering to me. The belt looks good, no cracks or obvious wear and the tension feels ok. I also plan on replacing the s-belt when I replace the t-belt* (Thanks Ensteele, I actually knew this as I just ordered it and plan on changing it out myself. Hopefully the car will run again).
Torquebind? Hmmn, that smells much more expensive. Perhaps I should investigate this.
So, the plan right now is to change the fluid (I'll use the turkey baster method), the reservoir O ring, and the s-belt.
Is there anything that I can do to determine if torquebind is the culprit?
Greg
Old 02-11-2007, 09:34 AM
While you are in doing the T belt, I would also replace the water pump.
Old 02-11-2007, 10:03 AM
Manarius's Avatar
Greg
Torquebind is a feeling more derived from the drivetrain. It feels like the entire car is trying to bind up. If you go to a parking lot and try to drive in tight figure 8's and the car shudders as soon as you start making those sharp turns, I'd be willing to bet you have torquebind, not issues with the power steering.
-Jason
-Obi Wan Kenobi
Old 02-11-2007, 12:32 PM
That is the easiest way to check for the torquebind issue.
Old 02-11-2007, 03:13 PM
Hop Hop is offline
Classic SVX
Yup,
I've got a new radiator, hoses, water pump, thermostat, crank and cam seals, t, s, and alt belts and a bunch of gaskets. Should be interesting. I've got my fingers crossed about the ps res o ring.
I looked around for info about the torquebind and found Tom saying:
"It's ALIVE!!!! The new tailshaft has fixed all ailments. My guess is that there was an abstruction of the transfer valve in the old housing which would not allow it to actually cut the line pressure. I know the Sol. C was working but the transfer valve was not."
Greg
Old 02-11-2007, 08:49 PM
svxstarship svxstarship is offline
How about putting the fuse in for front wheel drive only and seeing if it's still happening?
1999 Audi A8. No more SVX's for now.
Old 02-11-2007, 09:57 PM
Manarius's Avatar
That's a great way to test for torque bind. I always forget about that. Just put in the fuse, and try tight turns. If the car binds still, it's something not transmission related.
-Jason
-Obi Wan Kenobi
Old 02-11-2007, 10:00 PM
I forgot as well. Good suggestion.
Old 02-11-2007, 10:45 PM
Shuddering
I had the same exact symptoms around six months ago. AWD was stuck on all the time. I got a new c solenoid online and had subaru put it in. At two different Subaru dealers here the mechanics think that the clutch plates need replacing as well. Turns out mine were ok and just the solenoid fixed the problem. Check the tranny codes if you can. Mine did say the c solenoid. Good luck.
Mike
95 Pearl Blue L
