Old 04-16-2002, 09:06 PM
mb92svx mb92svx is offline
help with radio illumination bulb
Hi everyone,
My SVX radio/cd/tape unit blew the lamp that illuminates the radio station, and changing stations at night has become a problem! Has anyone had to replace theirs, and, if so, was it easy or complicated? I have never had my radio out of the dash, so I am unfamiliar with the radio removal / replacement technique.
Thanks,
Mike
I noticed that ALL SVX'ers say 1 of these 2 similar phrases:
1. "I need my SVX fix." (when they haven't driven it for awhile)
2. "I need my SVX fixed." (when it must go to the shop for repairs)
Old 04-16-2002, 09:17 PM
EverclearAtMSU
Re: help with radio illumination bulb
Originally posted by mb92svx
Hi everyone,
Thanks,
Mine would go in and out when I got it. I've read a lot of posts regarding this problem. I just replaced mine w/ a cd player. If you really care that much, it envolves removing the unit, opening it up and replacing a very small light on one of the sides of the LCD. Or ordering a replacement, or finding one in a junk yard.
Old 04-17-2002, 08:37 AM
Aredubjay's Avatar
Rat Fink Member ~:o)
I've looked at this problem, and, unfortunately, you'll need to do some solder work if you're going to replace it.
Unlike the CD player, the circuit board does not simply "unplug" from the rest of the unit. The pins are soldered in. You's have to unsolder the pins and pull the circuit board (after unscrewing the two screws on the front of the board). Then, you'd have to unsolder the bulb unit (the bulb and and holder are soldered onto the circuit board as a unit).
Luckily, I have two radio units. I plan on replacing the bulbs on one. If I screw it up, the bulbs will stay burnt in the "good" one.
Have fun!
Randy Johnson
Mike Davis -- at Reading VI
