Old 08-16-2004, 02:11 PM
simonton
parking brake
does any one else's parking brake seem to do nothing unless it's cranked as far as it possibly goes? It's not a big deal, but if there's some easy way to correct this i'd love to know it..
Old 08-16-2004, 02:33 PM
Mr. Pockets's Avatar
Moderator
You probably need to adust the cable. I've never done it myself, so offhand I don't really know where the adjustment is done.
But it can't be hard.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 08-16-2004, 02:38 PM
Actually, I believe the e-brake adjustment is under the center console.
Yup...part number 2 in the following:
Reference Link
Old 08-16-2004, 02:40 PM
n00b on demand's Avatar
Yea i was going to say the same thing. Adjust the cable and you should see better results. I need mine to be adjusted too.
Old 08-16-2004, 06:06 PM
simonton
what exactly do you do to the cable to adjust it?
Old 08-16-2004, 06:25 PM
Adjusting the Park brake.
To do it properly. You back off the cable adjuster through the console. Then adjust the rear brake shoes, through the backing plate. There is a small rubber plug that you remove, adjust the shoe adjustment till the wheel starts to bind. Back off the adjuster to free the wheel. Then adjust the cable through the console till the lever rises 6 to 7 clicks.
If you just do the cable, the lever will feel better, but the brake won't work any better.
Do it properly do it once.
