Old 10-14-2003, 01:02 PM
Originally posted by svx_commuter
I think that any smell of gas inside the cabin is reason for major concern. I have experienced this once on a car and it was leak on the fuel rail. Please make sure that your SVX is not leaking gas from any of the pressurized fuel lines. With the engine cold, turn on the engine and push and pull all the rubber fuel hoses and look for leaks. Maybe the line from the filter to the engine is cracked? Try pushing and pulling on the injector rail. Check the injector rail behind the alternator, this can salt corrode. Check the injectors, wiggle the top cap around. Check the fpr and return line. There is absolutely no way the smell of gas should enter the cabin if all is working well and a fire is not desirable.
Trevor, Is it possible for the CC system to give off gas if for some reason it's hooked up wrong or a hose has come off or something like a crack in the canister? What is that hose for on the bottom of the canister that goes into the fender space?
I donÕt think the tank venting system is a likely source because so little pressure is involved but anything is possible. You are absolutely correct in your concern regarding fuel leaks but I gather the smell is only noticed when the A/C is on and this makes it all rather a mystery.
The hose connected to the bottom of the canister is the Ō vent in the bottom Ō which I referred to through which fresh air is drawn during purging.
Old 10-14-2003, 01:14 PM
Originally posted by SVXRide
Trevor,
I don't have my shop manual handy, but wouldn't the same "doors" be open for the heat setting as the A/C setting - assuming the recirculate button wasn't activated?
-Bill
Hi Bill,
Like a fool I was working from illustrations in the manual which are not at all clear as my wife was out in the car but the flaps etc. are after the ducting I had in mind.
However I dropped a real clanger because on now looking at the beast in the flesh it is obvious that all the ducting is on the cabin side of the bulkhead. How silly can you get.
Old 10-14-2003, 01:40 PM
Originally posted by Bwana
Alright, i went snooping around my engine this morning, and couldnt find anything wrong w/ the canister or any lines around the engine. I did find a connector that was unplugged (see picture).
Anyone know what that is, and if it could be the cause?
Sorry can't help as my car has all those bits on the right and correct side.
I don't thnk it has anything to do with the purge control solenoid valve from what I can see of where it is placed but you could trace the wires.
Another thought.
The bonnet (hood) is sealed at the rear edge, just in front of the A/C intake vent, with a rubber compression strip. If this strip is damaged or out of place engine fumes might be drawn into the A/C system. Worth the simple check involved.
Old 10-14-2003, 03:17 PM
Green1995SVX
Scott-
Double check the fuel hoses near the fuel filter. They can commonly leak in that area.
Also. Change that brake fluid! GEEZ.
Mike
Old 10-14-2003, 06:11 PM
Bwana's Avatar
Bwana Bwana is offline
*Special* Member
Send a message via AIM to Bwana
I know...lol. As i hit reply, i thought: "How many people are gonna tell me to change my brake fluid?"
It'll get done soon, no worries.
[/COLOR][/COLOR]-Scott My Locker
2014 Grey Ford Fusion 2.0 EcoBoost Bought: 12-5-14
2005 Silver Legacy GT Ltd 5mt. Bought: 3-3-07 Sold: 12-5-14
1996 Brilliant Red L (AWD). Bought: 6-14-04 - Sold: 3-3-07 - 15.370 @ 89.65
1992 Claret/black LS #4086 (GF's). Bought: 6-30-04 - Sold: 7-29-07
1994 Pearl White LSi Bought: 2001? Sold: 2004?
Old 10-14-2003, 09:27 PM
Bwana's Avatar
*Special* Member
I looked again, and found the hose from the bottom of the charcoal cannister wasnt plugged in to the hole going to the fender...it was just laying on the bottom of the underguard.
Engine was too hot to plug it back in, but i'll do it in the morning, and then drive to school, we'll see. Somehow i doubt that's the problem, but oh well...
Old 10-15-2003, 12:11 AM
I guess you know, as I know, that you have not found the problem. All you can do is follow up on ALL the suggestions made here. Best of luck as you DO have a curly one.
Old 10-24-2003, 04:54 PM
No responses? Was it that hose causing the problem?
Old 10-24-2003, 05:37 PM
Bwana's Avatar
*Special* Member
Oh, sorry guys. No it was not the hose.
A little more detail:
Only smells after moderate acceleration (shifting in 4-5k range), and also WOT accel.
Smell gets exponentially weaker if the heat is on. (you'd only smell it if you were trying to smell it.)
Havent needed the A/C, so i dont know about that.
I'll try the "vent" setting tonight and see what happens.
P.S. There has been no change in gas mileage, or acceleration speed... No smoke out the exhaust, nothin *shrug*.
I'm tempted to just drop it, and let it be, but it's sooo strong i cant stand it anymore.
Is inhaling gas fumes bad for you?
Old 10-25-2003, 04:56 PM
Does it also smell like gas when you open the sunroof?
Old 10-25-2003, 04:59 PM
so you've been huffing on gas fumes for what, like two weeks now?
you may want to take it to a mechanic sometime soon.
1987 928 S4 (Black) SOLD!
1997 SVX LSi (Ebony) SOLD!
2013 G37xS (Obsidian Black)
Old 10-25-2003, 05:06 PM
Bwana's Avatar
*Special* Member
with no air on?
With the whole climate control off is where it smells the worst. I open the windows (and sunroof) to air it out if I dont need the heat.
You can barely smell anything outside the car, even with the hood open.
<-- Me.
I have seen no ill effects of this yet, so i'm holding off as long as possible before going to a shop.
Old 10-26-2003, 05:02 PM
svx_commuter's Avatar
The fuel lines run inside the rocker panels. Maybe there is a hole in the fuel line inside the car. That would be strange.
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 11-01-2003, 02:22 PM
gl1674 gl1674 is offline
Trevor,
The one major difference with A/C is that the radiator fans are always running - they shift air from engine compartment to under the car. This is warmer air, so if car is not moving (like sitting on traffic light), the air will rise and can be drawn into cabin compartment.
So far this is just a theory.
I just got the gas smell showing in my own car . It started 3 days ago and I get it only when car is warming up (~3-5 minutes after start) and only when it has been colder than 60 degrees outside. Searching, haven't found anything yet.
Old 11-01-2003, 03:38 PM
Have you checked the rubber compression seal which seals the back edge of the hood just in front of the A/C intake. If it is not OK engine smells could be entering the vent.
I mentioned this previously but have not seen confirmation of it being checked. Other than that I canÕt throw up another clue.
Š 2001-2015 SVX World Network
