Old 07-20-2003, 02:33 PM
SubaSteevo's Avatar
No longer blue member
T-belt cover gasket
Noticed a few drops of oil dripping from the bottom of my engine and they appear to be coming from the gasket around the timing belt cover (I think it's part #6 in this diagram http://www.subaruparts.com/diag/?mod...category=022-A). The leak has since stopped but there is a chip missing from the gasket. I have never had the timing belt cover off so I'm not sure exactly what's in there, is this a possible source of the leak or not? I know it's not from the oil filter, so if its not this gasket what else could it be?
-Steve
01' MSM Lexus IS300
Old 07-20-2003, 05:48 PM
Subafreak's Avatar
Superbeast
It's not the timming cover but whats behined it, the crank seal and or cam seals. Very common prob., make a search I'm sure you'll find much info.
Old 07-20-2003, 06:32 PM
immortal_suby's Avatar
Thread Killah
Agreed - if you replace the timing cover gasket it will last for 2 weeks before it swells from all the oil its holding and pukes it all back out again. I know - I tried. Check into the cam and crank seals, they are usually the source of the leak.
Locker Link
2015 BRZ Limited 6MT
Old 07-21-2003, 11:14 AM
SubaSteevo's Avatar
Question Seals
So I need to take the timing belt cover off to check the seals? Should I just replace both seals anyway, even if one is ok?
-Steve
01' MSM Lexus IS300
Old 07-21-2003, 11:30 AM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
Re: Seals
Yes.
If the car has more than 100,000 miles, you may want to consider changing the timing belt, water pump, oil pump and crank seal while you have it all apart.
Doug
1994 LSi (4/93)
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Old 07-21-2003, 12:19 PM
SubaSteevo's Avatar
Actually
My car has 87k. The previous owner had kept record of what mileage maintainance was done, timing belt was done at 61k, water pump at 30k, oil pump and crank seal have not been done to my knowledge. Should I still change them? From searching I think I could do the cam seal job and the water pump myself although I'm not sure about the belt. Is there much difference between the cam seal job and the crank? How hard is the oil pump to do? Any tricks besides the belt wrench to get the pulley off?
-Steve
01' MSM Lexus IS300
Old 07-22-2003, 02:37 PM
SubaSteevo's Avatar
Part numbers
I can't seem to find the cam and crank seals on subaruparts, does anyone know the part numbers?
-Steve
01' MSM Lexus IS300
Old 07-22-2003, 02:46 PM
mohrds's Avatar
806732150 Cam Oil seal-32x45x8 (two required)
806733030 Crank Oil Seal 33x49x8
This seal shows up on the diagram, but I don't know if it is behind the oil pump or in front of it.
806919050 Oil Pump O-ring 19.2x2.4
Have Fun!
Doug
1994 LSi (4/93)
2000 Ford Excursion
Old 07-22-2003, 04:06 PM
SubaSteevo's Avatar
Oh boy
Yet another wonderful SVX experience. The leak has since stopped so I think I'm gonna hold out a while since its kind of early to do the timing belt already so that I can just do all of it at once (plus time is at a minumum right now). Next oil change I'll switch to GTX high mileage (right now I'm using a synthetic blend) and hope that'll keep the leak under control until atleast 100k. Thanks for the part numbers!
-Steve
01' MSM Lexus IS300
Old 07-22-2003, 04:19 PM
SubaSteevo's Avatar
Anything else
So I'll need a timing belt(13028AA120), oil pump(15010AA133), oil pump o-ring(806919050), water pump(21111AA033), cam oil seal x2(806732150), and crank oil seal(806733030)...anything else? Any idea how much it would be to have a dealer do all of this?
-Steve
01' MSM Lexus IS300
Old 07-22-2003, 04:38 PM
mohrds's Avatar
Re: Anything else
The oil crank seal comes with the oil pump, the o-ring does not.
Doug
1994 LSi (4/93)
2000 Ford Excursion
