Old 06-18-2003, 07:56 PM
AFBeefcake's Avatar
Subaru Swapper
Noise from exhaust in park
When my car is in park and I rev the engine and then let off the gas I get a kind of pop noise. Is this a bad thing? I have a stebro exhaust and an air intake.
2005 Legacy GT
My WRX's Cardomain Page
Old 06-19-2003, 12:08 AM
mbtoloczko's Avatar
sans SVX
Re: Noise from exhaust in park
Too vague of a description. Can you get a sound file?
Mychailo
Visit my locker
Old 09-27-2003, 05:18 PM
In case you never got an answer...it's fine. Mine does the same thing with the Stebro.
Old 09-27-2003, 07:11 PM
AFBeefcake's Avatar
Subaru Swapper
thats what I thought
2005 Legacy GT
Old 09-27-2003, 09:27 PM
What the after market exhaust has probably done is bugger up the well designed OEM virtual extractor system and it would appear, from what is posted, that you are now getting unburned gas igniting in the exhaust system.
Old 09-27-2003, 11:20 PM
Phast SVX's Avatar
BOOOOOOOOOOOOOOOOOST
my 180k system "hiccups" when deccellerating..i wonder if a bad gasket is causing this? who knows
phil
~Phil
Old 09-28-2003, 12:02 AM
Phil,
You are exactly right, it is a very good idea to check for an air leak close to the manifold.
Old 10-18-2003, 07:59 PM
I also "mostly" fixed an exhaust leak immediately in front of the center cat. It will be completely fixed sometime this winter when the 5spd goes in.
