Old 06-04-2003, 05:15 PM
mbtoloczko's Avatar
sans SVX
rear spring rate for an LSi?
I've determined that the stock spring rate for rear springs on the 1995 L AWD is 110 lbs/in. However, in looking at the Subaru parts lists, there is a different part number for the springs on a 1995 LSi. Does anyone know the spring rate of the rear spring for this car? Maybe its in the service manual?
Mychailo
Visit my locker
