Old 02-29-2008, 06:33 PM
Ovidiu STAN Ovidiu STAN is offline
It will not start (from time to time)_ bad security module?
In about 5% of the time it will not start. When I turn the key, the starter would not engage, not a click, nothing.
After several attempts combined with the move of the shifter (maybe this movement didn't help actually) it will finally start like nothing happened.
The battery is good.
My first opinion is that the security is acting up disabeling the starter. Maybe is a coincidence but also when I use the remote the car would allways close but only sometimes open. I changed the battery on the remote but no change.
My other idea is that I may have a bad contact on the shifter.
I do not have a clear correlation between the remote malfunction and the car not starting but it is very possible.
Did anybody experienced the same issue?
What was the fix?
Old 02-29-2008, 07:25 PM
Trevor's Avatar
Trevor Trevor is offline
If you have the OEM security module, this does have a starter interrupt function and so could be the cause. However intermittent problems are very difficult to trace.
Check that the ignition switch mounting bolts are not loose, as this has often been reported as a problem. Do a search and you will turn up evidence of several possible alternative and obscure faults.
Trevor, New Zealand.
Old 03-01-2008, 07:06 AM
CorSVXette's Avatar
CorSVXette CorSVXette is offline
SVX- My daily driving Corvette
Send a message via AIM to CorSVXette
Classic SVX
I am by no means an electrical expert but what if you just unplug the security module and leave it unpluged for a while to see if that is the problem?
Paul
1969 Corvette
1995 SVX L Safety Option Package, HID's & Awsome Braking (Svxfilies/TomsSVX), JDM Clear Corners, JDM Boxer Engine cover, Transmission Cooler, AND NOW JDM FOLDING MIRRORS!
1995 Corolla
2003 Highlander
Old 03-01-2008, 03:00 PM
Trevor's Avatar
I do not know what type of security system you have. If you unplug it, depending on the plug connections, you could open the starter interrupt circuit so that the starter is prevented from operating.
My suggestion is that you try to get someone with electrical knowledge to assist you.
