Old 12-21-2003, 08:16 AM
Alcyone SVX LSL
Question starting problem...
i am gonna do a search and put this in tech Q&A also but this is the problem.
My car has been having a hard time starting off and on. I looked at the mass air flow and it looks dirty but should still work....i slightly cleaned the throttle body and i put a new coolant temp sensor in because the fans have been acting wierd. But still no luck finding the problem. I am thinking bout the timeing and checking each vacuum line but i would think this car should still start up the same each time i put the key in it...but right now i can go out and sometimes she will fire right up other times it make take 10 seconds or so. Anyone have any ideas??
Old 12-21-2003, 08:30 AM
immortal_suby's Avatar
Thread Killah
Are the sparkplugs in good shape?
I also had starting problems after adjusting the TPS. Rotating it one way it wouldnt start unless I had my foot on the accelerator. Rotating it the other way it fired right up.
Maybe a new fuel filter and some drygas in the tank would help?
Locker Link
2015 BRZ Limited 6MT
Old 12-21-2003, 09:06 PM
Alcyone SVX LSL
clean gas...plugs have 2000 miles on them might be the TPS...been thinking bout that...once she is started she runs great. odd, but i am messing with it...thinking about cleaning out the whole top end....throttle body, intake, valves, injectors. and fuel rails....might be worth the effort. All the fun you can have with a SVX
