Old 08-06-2009, 03:14 AM
Alex-svx's Avatar
Alex-svx Alex-svx is offline
US over to europan.
Hello
Its me about the transmission.
Now i really confused. One tell me i just ave to change the C-solendion and one say TCU. And when i think i understand, Then its not work?
Can i RELLY use this tranny or NOT?
Can i JUST cange the C-soledion?
Or must i Change the TCU??
Sorry but i relly need help to understand this.
My car is allmost done now, i relly like to drive it again. But i dont understand a thing about this Tranny trouble.
What must i doo and what can bee done?
Alexander (Norway)
My subarus:
1992 Svx LSI 5-MT(3.54)
1998 Legacy BG 2.5L GX
Old 08-06-2009, 05:14 AM
Re: US over to europan.
You have two options.
1.Remove the US trans and install the proper VTD transmission.
2. Experiment and fit a new solenoid C inside the US trans. This is what you have been waiting for, I hope sooner than later someone can get it to you. IF not, I have a used VTD extension housing here, I could send one over if needed but I would rather not take it apart.
Old 08-06-2009, 06:06 AM
Alex-svx's Avatar
Ok. so that is my only option if this can possible work.
To change the tranny rigt now i cant afford. So then i just have to hope for the s-solenoid then?
Alexander (Norway)
My subarus:
Old 08-06-2009, 04:06 PM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Aside from the *random speculation* about whether changing the C solenoid can enable a Euro TCU can operate a US gearbox properly, there is another issue.
I'm not sure if anyone has mentioned this yet, but the Euro TCU will not work with the US Speed Sensor 2. So you will need to fit a euro type speed sensor to the US gearbox. That has been done before, there's a long thread about it somewhere.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 08-06-2009, 04:32 PM
It has already been done as far as I know. Harvey helped him set up the appropriate modifications to use the proper speed sensors. If you cannot find a solenoid C for a VTD trans in the next week, let me know and I can ship you the one out of the VTD extension housing I have here
Old 08-07-2009, 03:03 AM
legacyau legacyau is offline
hi tom can you post a pic of the offending solenoid i may have an avenue of supply but i need to see one to confirm correct part
cam
Old 08-08-2009, 05:07 PM
Trevor's Avatar
Trevor Trevor is offline
It has been done in Europe, but THE C SOLENOID WAS NOT CHANGED and the ORIGINAL N/C SOLENOID RETAINED. A US TCU was installed.
All exactly as i have been stating, over and over.
Trevor, New Zealand.
Old 08-06-2009, 04:37 PM
oab_au oab_au is offline
He has done the No.2 speed sensor swap Phil, so it is set up to run with the VTD TCU Just needs the VTD C. solenoid to match. Its the best he can do.
One Arm Bloke.
Tell it like it is!
Old 08-08-2009, 05:47 PM
Trevor's Avatar
Harvey,
The solenoid MUST match the transmission in use, NOT the TCU. The same increasing/decreasing pulse length signal, is applied by both TCU. The "phasing" is NOT reversed.
This IS the very REASON for the different solenoids in respect of the two transmissions. Reversing the action of the solenoids corrects an otherwise incorrect signal, thus preventing the need for any mechanical alteration.
I have explained all this umpteen times. You have accepted my corrections of your previous statements regarding the difference in solenoids. (Without any apology.) But even though at the time, I pointed out in exact detail, the reason for the change in solenoid, obviously you were unable to comprehend.
Old 08-09-2009, 06:16 PM
wait a sec, I just had a thought that might just work....
When we did the PhaseII 4eat swap we need to use a speedo corrector to slow down the pulse for the #2 speed sensor so the ECU TCU and Speedo were not winding WAY out. What if we wired this inline to ONLY the TCU speed sensor #2 input into a US TCU. Everything else being as it was in the car but adding this and adjusting pulse signal down to normal readings for a US VSS#2. He would need a Select monitor to monitor the TCU's reading to adjust it properly but it should work and allow him to use the US TCU and will fix the issue.
The biggest problem is he would need to find someone capable of doing it
Old 08-09-2009, 06:28 PM
Trevor's Avatar
But damn it, both you and Harvey have instructed Alex in no uncertain manner, that he should change the existing N/C solenoid for a VTD N/O. This instruction MUST be withdrawn and cancelled.
Old 08-09-2009, 08:12 PM
Would you stfu for two seconds. I didn't say the solenoid would be flawless, I said it would keep it from binding.
This still doesn't help the fact that he needs to find someone capable in doing this.
Old 08-09-2009, 09:00 PM
Trevor's Avatar
I will not shut the fock up. Agitation is apparent, because your errors have been exposed.
What you said is of no consequence. The incorrect solenoid will completely reverse the operation of the transmission, relative to the signal received. It will NOT keep it from binding. It will be useless, NBG and a stupid alteration. It would NOT be "OK but not flawless." If will be 100% wrong.
You continue to uphold your incorrect statements, for no other reason than the maintenance of pride.
P.S. What you have to do, is counter the exact information I have set down, with what you consider correct, portrayed in similar exact text. Otherwise you have no fooking argument.
Old 08-10-2009, 02:37 AM
longassname's Avatar
Just some dude.
Significant Technical Input
Alex,
I suggest you stop posting here and privately ask phil for assistance to get you out of your bind (since he is european)(including ignoring the pms you are sure to be getting from both sides of the flame war). I aggree with what he has said and I believe it is very fair to say that he and I are the two most knowledgeable people on the subject.
