Old 03-11-2009, 03:46 AM
subbieatnz's Avatar
subbieatnz subbieatnz is offline
Rear Diff Questions
Quick question. Is there any procedure you have to do when putting rear diff in SVX?
also should i replace the seals? where the CVs go into etc?
and what grade oil should i Use in SVX rear diff?
Thanks
1992 NZDM SVX Maroonish Red/Black ( 1st car ive owned with an cd player ) Has been retired
1989 Vortex 6 Maroon
1983 RX Silver Grey
1973 1400 GSR Yelo 2 Door Coupe awaiting Restoration
Old 03-11-2009, 02:21 PM
NiftySVX NiftySVX is offline
Re: Rear Diff Questions
I would replace the seals while you have it out, that's pretty much standard procedure. It's really piece of mind because if the oil leaks out it will toast the diff and it only holds like 3/4 of a qt, so it might leak enough out to damage it before you noticed. Make sure and put wheel bearing grease on the seal lips so they don't stick, if the new ones don't come pre greased or you reuse the old ones. Also, check the inner joint cup for wear where the seal lip contacts the sealing surface. If there is any groove worn in it you will need to either replace that inner cup or simply install the oil seal at a different depth so the seal doesn't ride in the groove. Also, check for this same groove on the outer cups as this can cause water to leak in and take your wheel bearings. This was common on the first generation legacys. As for oil, the manual calls for 75/90. Also, it is reccomended that you use some liquid gasket on the threads of the drain plugs, but this is rarely done in practice.
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
Old 03-12-2009, 02:38 AM
subbieatnz's Avatar
Thanks for that.
how do you go about making sure the diff is filled to the right leavel?
and how do you go about filling it?
Thanks
1983 RX Silver Grey
Old 03-18-2009, 02:47 AM
subbieatnz's Avatar
Originally Posted by subbieatnz View Post
Thanks for that.
Thanks
do you just have to fill the level to the 2nd bung in the diff? like the 1 up the top?
1983 RX Silver Grey
