Old 09-22-2008, 09:50 PM
stiguy's Avatar
stiguy stiguy is offline
wrx auto tranny?
i know some other auto trannys from some other older subaru's work
but what about a wrx auto tranny would wouldn't that work since a 5 speed works on it?
Old 09-23-2008, 02:48 AM
SomethingElse's Avatar
word words wording
Re: wrx auto tranny?
No, will not work unless u want to do lots and lots of not fun wire/computer stuff. The trannys most commonly used are plug and play. manual trannys have 2 plugs so splicing is not a major issue.
Eric
Old 09-23-2008, 05:53 PM
Don't see why it won't, it is just a normal 4eat box, would run off the SVX TCU OK. Or have I missed something?
Old 09-23-2008, 06:03 PM
Soob started going with "phase 2" trannies in 1998, some models had the "phase 1" till 99. The phase 1 has an brake band adjustment nut and no external mounted filter. The Phase 2 has no external adjustment and an external screw on filter. There are also electrical differences between the phase 1&2.
Physically the phase 2's will bolt up, but you would also need to rewire and use the newer TCU, and wire the newer TCU into our ECU.
Old 09-24-2008, 08:50 AM
but wait, there's more!!
The phase 2 transmissions have different dimensions so a custom X-member would be in order. Not to mention a modified driveshaft... I have been meaning to get back to this project for some time now but finding a phase 2 tranny for next to nothing with a TCU to match has proven to be troublesome... I still want to do it though as it will open up our transmission availability greatly and most phase 2 4eat's have a 4.44 FD
Old 09-24-2008, 09:48 PM
Hondasucks's Avatar
Subaru Technician
Even better, I wonder what it would take to use a 5EAT? Even cooler would be the 5 speed Tiptronic with paddle shifters... (And I know it exists, look what I found digging in the data screen on the Select Monitor
1986 VW Jetta
Old 09-25-2008, 06:57 AM
aparently someone in Japan has done it already... don't know the particulars but I don't see why it couldn't be done with some time and effort
Old 09-25-2008, 05:58 PM
gstape gstape is offline
do you think the phase 2 transmission could be run with the phase 1 (svx) TCU?
I don't a lot about this, but it seems like it would be likely that the I/O is fairly simmilar? THat is 2 speed sensors, band control solenoids, pressure control solenoids, torque convertor lock up, etc. Allowing the Phase 2 to run on the Phase 1 TCU
I've run a EJ25 NA engine in an Impreza that originally had a EJ18, and ran it with the EJ18 ECU. There was some splicing involved obviously to get connectors to match, but It runs quite well.
Old 09-25-2008, 06:27 PM
no the speed sensor signals have different outputs as far as I have reearched... but it has been about a year or so since I looked at everything
Old 09-25-2008, 08:45 PM
stiguy's Avatar
5EAT? what subarus have them?
Old 09-25-2008, 09:26 PM
redlightningsvx's Avatar
Collision Refinishing Tech
I think its 2000 and above but i'm not sure. I know the 2002 wrx has one.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 09-27-2008, 08:10 AM
Nevin's Avatar
Nevin Nevin is offline
It would have to be an older...JDMer wrx tranny. As previously mentioned, it would have to be a pre-'98 tranny, and in the U.S. pre-'98 there was obviously no such thing as a WRX so it would have to be a tranny out of a JDM WRX auto.
I was lucky enough to find such a tranny. It is out of a '93 WRX auto wagon with 93k km.
4.11 gears + more clutch packs than the N/A trannies = goodtimes
Jesus is the remedy
2015 Expedition EL Ecoboost
