Old 09-21-2008, 08:21 PM
Re: How to test the Crank Angle 1 & 2 and Cam Angle Sensor.
Originally Posted by Dessertrunner View Post
Tom what do you mean by CTS, sorry to be so dumb? Also it wouldn't start on really cold mornings when the car temp went below 0C.
Tony
He meant Coolant Temperature Sensor.
Sounds right...
Old 09-22-2008, 04:01 AM
Dessertrunner's Avatar
Here is the scope image of a good cam sensor plan to change to a bad one and see if anything shows up.
Tony
Old 10-08-2008, 11:08 PM
AUSVX AUSVX is offline
Registered Loser
Hey I'm also having no luck finding which sensor in the car isn't working properly... I check codes regularly but nothing.
1----
Twice in the last 9 months I have started the car in the morning and everything is perfect and about 2 minutes into driving the engine vibrates like crazy, revving it feels like it's going to ruin the engine. I stop and start the engine and it's still there.... After a few start and stops everything is perfect again. (I've read something once about one side of the engine shutting down is this related?)
2----
If I start the car in the morning everything is perfect.
If I turn off the car after completely warmed up and start it straight away it's perfect.
If I turn off the car and come back 2 hours later and start the car the engine keeps on turning over and over and eventually starts.
Any suggestions?
Have changed coolant temp sensor and gauge temp sensor (the one just above the coolant temp sensor. After installing them a few months ago I disconnected the battery.. left it disconnected overnight to reset everything
Thanks, Jordan.
Old 10-08-2008, 11:25 PM
mysvxrocks's Avatar
mysvxrocks mysvxrocks is offline
Im REALLY addicted! CANT STOP!
Send a message via MSN to mysvxrocks Send a message via Yahoo to mysvxrocks
I had one of those sensors go bad on my 92. The car wouldnt start, period. I picked up all three out of a wrecking yard car, put them all in, and it started right up. I have no idea which one was bad.... Codes said two of them were. I priced them new, and omg... $250 a piece, if you can even find one... So stupid...
D.J. McPhee
2006 Infra-Red Ford Focus ZX3 ~ 67k
No longer SVX'n, Ill always miss them!
1995 Polo Green LS-i ~ 95k
1992 Dark Teal LS-L ~ 145k (04/91) #2231
Old 10-09-2008, 03:47 AM
Jordan
Did you ask Brooky, two of the sensors are the same so if you get one you can swap them over. My guess is the cam sensor near the battery.
Tony
Old 10-09-2008, 05:05 AM
Registered Loser
Hey I didn't ask brooky because both cars had no engines and wiring harnesses... I just assumed they had been bought by someone else already, might still be worth giving them a call
Are the cam and crank sensors shared with any other Subaru?
Thanks for the help guys!!!!!
Old 10-09-2008, 04:10 PM
The cam and one of the crank sensors are the same as the Liberty units, the other crank sensor is SVX only.
Old 10-11-2008, 05:04 PM
Okay finished the testing to see if a difference appeared on a bad crank or cam sensor showed up on a scope. The good news is it does. What happens is the sensor still sends a signal but wave pattern is not were it should be as regards timing. I also sprayed freeze spray on the sensor when it was cold and the wave form moved out of aligment. If you have a look at the two images you will see one is clean and the other has a ghost wave, it is the bad sensor.
Old 10-11-2008, 06:06 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
So, you've confirmed that a 'scope is mandatory to determine if the crank angle and cam angle sensor are bad (?)
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 10-11-2008, 06:13 PM
yes. The scope can pick up the problem when the ECU doesn't. Also you can test the knock sensors. Its surprising how bad the signal can be and the car shows no major signs.
Tony
Old 10-11-2008, 06:21 PM
XT6Wagon XT6Wagon is offline
1----
2----
Any suggestions?
Thanks, Jordan.
Check your battery cables for corrosion. The negative cable on mine had the body ground mounting point corroded to the point nothing much passed. The battery end of both cables were terrible too. I think the sensors start to read really screwy when you say have a .5 V drop from the engine/ecu to the battery on the negative side. More so since corroded cables will have a non-linear response to increased load.
This will give you a clean baseline to start with on your sensors and infact checking the ECU ground seems to be Subarus #1 thing to recomend in troubleshooting anything dealing with the engine
Old 10-11-2008, 10:27 PM
Registered Loser
Hey thanks a lot for the tip im looking into that, I really wouldn't be suprised if that's what it is as well as crank and cam angle sensors.
Jordan.
