Old 08-21-2008, 09:00 AM
dennyo dennyo is offline
Question rear wheel bearings
i know alot of you have replaced rear wheel bearings and now mine are getting to the point where they have to be changed.I'm wondering if aftermarket bearings are any better than oem.Anyone have any suggestions?Experience? Thanks. dennis
Old 08-21-2008, 04:05 PM
kwren's Avatar
kwren kwren is offline
Re: rear wheel bearings
Bearings should be about the same with a few exceptions. Probably in most cases your choice of brands would be made in the same factory.
Keith
Old 08-21-2008, 07:55 PM
stiguy's Avatar
stiguy stiguy is offline
one of mine went the other day so called the subaru dismantler they sold me the hole unit with a good bearing and a year warenty for about the same price minis the price for pressing the bearings on. and with out the mess easy fix if your short on time or on a tight budget.
Old 08-22-2008, 08:34 AM
thanks for the replies.looks like i'll go with oem.probably going to replace the trailing bushings as well.they seem to have a lot of play in them.
Old 08-22-2008, 08:59 AM
SVX_MY_BABY's Avatar
Might as well since it's all apart. You may find you need to replace the whole arm just to get the bushing.
Earthworm was looking into having these bushings made.
http://www.subaru-svx.net/forum/show...=poly+bushings
Don't forget to check the rear swaybar bushings.
http://www.subaru-svx.net/forum/show...thworm&page=23
Old 08-22-2008, 01:15 PM
I hope I don't have that much trouble.I've already got most of the bolts loose(good ole pb blaster) and it looks like heat should loosen the two others.Whether they come out of the bushings is a different story.The bolt that holds the trailing arm to the subframe looks like it could be a problem! I've already replaced the swaybar links and bushings last year.Thanks for the tip about the arm,if it's too much trouble i will probably just swap them out with new.
