Old 06-08-2010, 04:56 PM
ScottyB's Avatar
ScottyB ScottyB is offline
Re: Vibration from driveshaft
Just kidding. There's definitely still a problem.
I moved for the summer to a place with no garage, so I decided to bring the svx into a mechanic. He said that the drive shaft is bent and the the viscous clutch seems to be engaging and disengaging randomly at idle. I noticed this myself, but wasn't sure what to make of it. He said that he figured that whatever is wrong with the transmission probably caused the drive shaft problem. He also said to see if I can get another transmission from the place where I bought mine. I'm thinking probably not, because I got the tranny a while ago and I did all the work myself...
Anyway, any suggestions? Could this be electrical? I was getting the tranny code indicating the dropping resistor is bad (according to a few threads). I checked the resistor with a multimeter and it couldn't read a resistance, so determined it was bad. Could this dropping resistor be the problem or is there something else to look at / try? Thanks
97 Toyota 4Runner SR5, 5 spd
92 Ebony SVX AWD (4.44 gears)
Old 06-08-2010, 05:23 PM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
Get a 4.44!
Old 06-08-2010, 05:29 PM
Originally Posted by Freeman View Post
Get a 4.44!
look in his signature
Old 06-08-2010, 08:41 PM
ScottyB's Avatar
That's what it is...
Old 06-09-2010, 05:16 AM
Since you know you need a dropping resistor, I'd install one of those first, as it's super easy to install...then with that out of the way start again with diagnosing it...as I think the dropping resistor has something to do with line pressure in the tranny, so it could be causing problems.....
Old 06-09-2010, 08:15 AM
Freeman's Avatar
Unregistered User
Lol, oops.
Fine, get two 4.44's and glue em together.
Old 06-09-2010, 09:57 AM
ScottyB's Avatar
Lol, oops.
Good idea
Old 06-09-2010, 10:39 AM
ScottyB's Avatar
Yeah, I'll give that a try. Where is a good place to get them? If I remember correctly it's a 12 ohm resistor with the ability to dissipate 100W of power?
Old 06-09-2010, 11:14 AM
Probably several floating around on here from people who have swapped a manual tranny into their SVX and don't need it any more..
So post a "Part Wanted" in the classifieds...I think I've already given away the ones I had..
Old 07-12-2010, 08:49 PM
ScottyB's Avatar
So, I got a resistor but there is still 16 flashes of the power light upon startup. When i pull the code it still says 11. I checked the resistance of the resistor and I get 0.9 ohms. I am getting the hard shifts, 3rd gear 'bounces' when shifted into manually. From what I've read this is caused from the incorrect resistance, but I'll deal with that later. The main problem of vibration still exists and that makes the car un-drivable above 35mph.
I've brought the svx to 2 different shops, a foreign auto shop and a Subaru only shop.
The foreign auto said my viscous clutch wasn't working properly and my driveshaft was bent. I replaced the drive shaft and the vibration is still there.
I brought the svx to a subaru only shop and they say the power light blinks 16 times indicating a faulty clutch duty solenoid. Other than that they said they couldn't really figure out why the car is vibrating.
I know that 11 blinks means duty solenoid A, and more likely the dropping resistor. Ever since I've had the car (2 years) and with each transmission (3 now), the power the power light has always said 11. So, i'm guessing that it's the dropping resistor and not that all 3 transmissions had faulty duty A solenoids.
Anyway, I guess i'm going to get it towed to a shop in Boulder that has more experience with Subarus...
-Can internal transmission clutch problems cause bad vibrations?
-Maybe the transmission that I got from the yard (this is when all the problems started) was damaged in some strange way from an accident?
- Can the rear differential cause anything like this? (when all 4 tires are in the air, the vibration is still there so I would say that rules rear diff out but who knows)
-TCU?
Old 07-12-2010, 09:33 PM
Cam Cam is offline
If I remember correctly trevor posted an in-depth description on this forum about the solenoids in the transmission. IIRC, Duty Solenoid A controls a pilot valve that in turn disrupts the flow of hydraulic fluid which is how it controls line pressure. I would think that if it is malfunctioning, it could be behaving erratically and may have negative results on the transmissions friction materials (I don't believe that would explain the shaking). Maybe one of the more knowledgeable folks on here could help out more on that, I am definitely NOT a transmission guy.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 07-22-2010, 08:53 PM
ScottyB's Avatar
I replaced my drive shaft and that didn't fix the problem so i'm going to replace the center differential now...
Does anyone know if the center differential is the same in the 4.44's and 4.11's stage 1 4EAT?
Old 07-23-2010, 04:49 AM
did you have the proper rear differential installed when you changed the trans? Did you check the tooth count to make sure it was a 4.44??
Old 07-23-2010, 08:30 AM
ScottyB's Avatar
Yeah, I remember checking the teeth on the ring gear and dividing it by the teeth on the pinion and it was 4.44. I could double check because I did save the ring gear from my 4.11 and original 3.54. Maybe one of those accidentally made their way in there...
Old 08-07-2010, 07:13 AM
ScottyB's Avatar
So the rear diff is geared correctly, but I did find this:
This is where the transfer clutch attaches at the rear of the transmission (crappy cell phone pic)
It looks a little burned and there are grooves, which I don't think are supposed to be there. I'm going to get a new clutch pack and see if it helps
