Speaker replacement
It would appear that the speakers in my car are crumbling to pieces, Fortunately I have some large speaker suitable for the rear that came out my Pajero Evo and with a bit of cursing have got them in the rear. My car is the CXD with the Panasonic double unit and the cd caddy in the rear. I've popped out the front component tweeters and they fell to pieces but I'm having a problem getting the door cover off to replace the 4-5 inch speakers which are also flapping about does anyone know how to remove the door card? so far I've removed to two screws and popped the fixings but it wont go any further and I don't want to butcher it, also any idea what the wiring is, the tweeter has a resistor am I right in thinking thats signal and the other is earth?
Re: Speaker replacement
Removing the door panel is easy. There are 5 screws. Open the door and take out the 2 screws on the front edge of the door panel, near the door hinge. There is another screw located under the door handle, hidden behind the plastic plate which justs pops out with a small-bladed screwdriver (preferably magnetic) There are also 2 more screws hidden under the felt mat inside the door armrest. Just peel it away to expose the screws, These are the most important ones as they hold the entire armrest to the door frame. You cannot remove the panel with these screws in place. Once all screws are removed, just pop the clips around the bottom of the door panel my pulling gently. Once free, lift the entire panel up slightly and pull away from the door frame to see the wiring. There are 2 electrical connectors that must be disconnected; one is for the power window switch cluster and one is for the door courtesy light. Replacement is the reverse order. The only possible minor hassle is lining up the door lock button to slide into the door panel opening, but usually it is not a problem. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 06-22-2015 at 09:21 AM. |
Thank you do you have any idea as to which wires are which for the speakers?
http://ae64.com/AudioInstall-2.htm#2...adioConnPinout
This help? The wires should be the same color on the speaker side as on the radio side. (column A) Unfortunately I ripped out all the original wiring and ran new wire, so my pics would not be helpful. Far as the tweeters go, I agree that the filter should be on the + line. So the one without the filter is your ground. But once again, my pics wont help because I went with aftermarket tweeters with there own external passive crossovers. Last edited by Lookin4SVX; 07-26-2010 at 02:12 PM. |
Thanks I'm going to work on the basis that the wire with the capacitor is the signal as I'm sure it must be. I have had no trouble with the door speaker as it had + on one and I have replaced that with a 51/2 component that fits just right and I've superglued the new 1 inch tweeter under the existing dash mounted tweeter grill so all looks stock.
Just to let you know, the stock speaker is 6 1/2 inches. 5 1/2 would probably work as well though.
