Magnaflow Exhaust BUZZ
Okay so i had some performance exhaust added to my svx Magnaflow and am regretting it. Around town driving(3000Rpm) acceleration there is an extremely annoying buzz coming from the back end. I took it to a friend and they said it was in the pipes or the resonator/muffler is messed. I've heard other problems with the custom exhaust and having the buzz... Any way to get rid of it... Im taking it back in on tuesday next week so i'll ask then...but i just want to see if theres an obvious problem...Iits not heat shields or anything loose either cuz ive already checked...thx in advance Benny.
is that buzz actually your exhaust system itself...i mean that some exhaust system setups.....well...lets' say when you see a cheap fireball exhaust on some piece of **** civic...that would buzz.....
i think it might be just the setup itself. ~ higher air flow
1992 Subaru SVX LS~L Ebony Pearl 1992 Dodge Stealth R/T Firestorm Red 1992 Subaru SVX LS~L Pearl White 1992 Subaru SVX LS~L Ebony Pearl JDM 6MT/DCCD 2007 Subaru Legacy Spec B. Diamond Grey Metallic |
Im assuming you removed your front cats. if so then you need to put some back on..there are some on ebay you can pick up pretty cheap around 45 bux shipped each. thats what I had to do ...
Magnaflow also makes some nice 2" in 2" out precats. I believe the part number is 50004. They are kind of expensive, but I am going to get them for my exhaust to put them in place where stock ones used to be and get rid of that buzzing at 3k. The rest of my exhaust is all Magnaflow so I figured might as well stay with the same brand.
i think the mechanic removed all the cats...precats and main cat...i told him not to but he did anyway...thats the reason i guess...that sucks. i hope he redoes it...he probably junked it all..oh well
holy crap...took it back to him and he blamed it on my exhaust tips...(i used the stock ones) the resonation sounds liek its coming from the muffler...im thinkin im gonna call his bluff to charge me for those tips. i think thats retarded honestly...having stock tips and a high flow exhaust can't cause a large resonation/buzz can it? it's the precats/cat being removed. even so, is there someone who can verify anything for me?
Stephen |
Yes we're not supposed to remove cats either but, at least here, there are no smog tests.
same here, but no emmisions testing= mad removal. lol
98 Impreza Wago-O-Doom & Datsun Roadsters |
In alberta there are no emissions tests and you can get away with it for now...
UPDATE! it apears actualy like he didnt remove the precats just the cat so it goes precats into a custom y into a resonator into the magnaflow(Motorsport#). The resonation starts in/around the y and continues...from behind the exhaust doesn't sound too bad but from the side it sounds like a go-cart...is there too much airflow into the y pipe? or what? |
