Re: Individual Throttle Bodies.
We are all in the same boat, trying to get this engine to put out some real power in the higher rev range. The writing was on the wall, when Matt did his engine, he did all that he could do as far as cams, duration and lift, and light weight solid lifters. It should have revved HARD, and put out the power that he was looking for. When it came to seeing what the results were, it would not put out torque up the rev range. As I told him then, it was the standard inlet/exhaust manifolds that were hold the torque peak down to the resonate, 4800/5000 rpm. As the rules prevented him from modifying them, there was nothing he could do, to bring the torque peak, up the rev range. What you are looking at, can be done, but it would take a lot of work, a lot of money, and if it was designed to length, it may do the job. The inlets would have to bend over the top to get the length in, then there has to be air cleaners, and trying to get cold air to them. The same result can be got by modifing the standard inlet, and doing a set of short headers, all tuned to the higher rev range. Harvey.
Harvey haven't heard from Matt lately but the rules I am racing under will allow for extrators so I will fit them. When we talked about the issue of cams at the start of my build I figured we need to do somthing about the inlet and exhaust flow so thats the plan.
When you see what happened to Rally Bob's intake under vacum it is hard to not come to the conclusion that that engine was starving for air inspite of all the understanding that the throttle body is big enough. The plan is to buy them with a plan figured out how to get them ontop of the existing injector manifolds and look at what is above as we go. I have asked about 90 degree bends on the ram pipes or what ever else may be aviable. Attached is two photos of manifolds we are dealing with. Tony
Okay a bit of an update,
Got the quote for the throttle bodies and it is $525 Aust per bank so for 6 uints its $1,050. To this I still need the linkage and the return spring with stopper. I measured the inlet size on the injector manifold and its 45mm so the plan to use the 45mm throttle bodies is correct. Tony
1995 - SVX 700,000 K Mine, DMS Struts to lift car 2in. Tyres Wrangler Silent Armor 235/70R16, PBR Radiator. 6 speed with DCCD and R180 rer diff, Heavy duty top strut mounts front and rear. Speedo correction box fitted. New stero (gave up on the old one). Back seat removed and 2 spare tyres fitted for desert driving. ECUTune SC sitting in the box for the next SVX. 1992 - SVX 255 K Wife (Want to stay Married so not allowed to fit SC) 1992 - SVX Pearl with black roof race car roll cauge etc ready to race. Ex Tasman Targa car. 1995 - SVX Green low k mint condiation. 1995 - SVX Rally car, ex Matts car. Now to be used on track. 1992 - SVX red & Black being converted to Mid Engine. 1995 - SVX Red 143,000 bit rough. Owned 5 others Subaru back to a 1974 1400 GSR. Last edited by Dessertrunner; 07-13-2009 at 04:49 AM. |
great info.
1992 Midnight Black LS-L - Sold 3/3/06 1991 Toyota MR2 - Sold 11/27/07 1992 BMW 325i - Tokicko Suspension |
I reckon the noise it will make will be worth every cent spent on it I remember a guy using twin downdraft webbers on an ea81 to great effect, it made a good noise too!.
Tony are you going to use individual sock aircleaners on each TB ? cam |
Subscribed for updates...
Its worth having a look at this setup on another forum. Here is the link and one photo.
http://forums.nasioc.com/forums/show....php?t=1175829
1992 NZDM SVX Maroonish Red/Black ( 1st car ive owned with an cd player ) Has been retired 1989 Vortex 6 Maroon 1983 RX Silver Grey 1973 1400 GSR Yelo 2 Door Coupe awaiting Restoration |
If you end up with solid works files for needed parts and want to send them to me I can run them through solid cam and let you know what it will cost to make them.
This is the current kit being suggested looks impressive. This is for 4 cyclinder but we would have 3 each side.
Tony
They look AWESOME!!!!!
#28
Damn thats looks so nice clean and smiple
#29
As I see it now the ram pipes may work but I am concerned about the engine getting hot air from the engine bay. For that reason I am going to give a different approach a try. Where the throttle are now I was going to built an airfilter box and force feed the air through a bonnet scoop. In that was any pressure loss by still having the manifold may to a degree be overcome by forcing the air into the intake and the individual throttle bodies. I am also hoping to be able to raise the manifold by 20mm.
I have positioned two standard aircleaners to show what I mean in this photo. Would like to here if we anyone thinks I can get the 20mm under the bonnet. Tony
#30
