Old 06-21-2008, 05:54 PM
ABS control unit
I went to svxipedia to check about abs codes. It says the control unit is under the right front seat. I checked and they're is nothing there. I have a 95 L model. Could someone please tell me where to look for this. The abs on the dash is staying on. When I shut the engine off the abs module under the hood continues to make a noise like it is running. I had the same thing happen around two years ago and disconnected the battery and the relay fuse under the hood and the problem just went away. That procedure is not working this time. Thanks.
Mike
95 Pearl Blue L
Old 06-21-2008, 06:10 PM
Re: ABS control unit
Mike
It's underneath the carpet behind the raised crossbeam. It is on the extreme right.
It must be there. You will probably have to release the carpet from under the trim to get access to it.
It has to be there.
Old 06-21-2008, 06:13 PM
What you have described sounds like a possible bad relay. They are usually two types, always on or always off.
Sounds like yours is sticking.
Old 06-21-2008, 06:17 PM
Thanks Joe for the quick reply. I'll go check again under the seat to access the code after driving it a few minutes of course.
Mike
95 Pearl Blue L
Old 06-21-2008, 06:18 PM
There is a small flap cut into the carpet to allow access to the code light. I'm not sure, it may be possible to see it with the seat in place, but to find it the first time, I'm sure it will be easier to remove the seat (5 x 14mm bolts).
Old 06-21-2008, 06:41 PM
You are right Dave, I should have mentioned that.
Take the seat out.
Old 06-21-2008, 08:43 PM
kwren's Avatar
kwren kwren is offline
http://www.ourlifeline.net/blue_thunder.htm
Keith
Old 06-22-2008, 05:36 PM
I found the unit under the seat. I took the seat out but really didn't need to. I am getting a #9 code. Nine blinks. Faulty motor and/or motor relay or broken or shorted harness. Could the problem still be the relay in the fuse box under the hood? BTW the car drives fine with no problems. I just disconnect the battery when not driving so I don't drain my battery. Any guidance on this appreciated.
Mike
95 Pearl Blue L
