Old 03-09-2013, 11:39 PM
B 4 You's Avatar
B 4 You B 4 You is offline
#lolsvx
ABS Light on after suspension change
A friend helped me put in my new strut mounts tonight. It was a total success, but when I took it for a test drive, the ABS light was on. It didn't come on at idle, but after a few feet down the road it came on and stayed on. Tomorrow I'm going to check to see if I knocked a sensor off or broke one. Anything else I could have done? And if I did snap one, should I just buy a used one from somebody?
1992 Pearl White LS
Owned since 2009
175k Miles
2005 WRX manual swap
Rear wheel drive
K-Staff front bumper
Delta Speed side skirts
JDM clear corners
Smallcar grille
Subaru XT steering wheel
Subaru XT shift knob
First bagged SVX in the world
Old 03-10-2013, 11:18 AM
scoobymal's Avatar
scoobymal scoobymal is offline
Re: ABS Light on after suspension change
Check your connections, and check the codes, the blinking check light is under the seat (passenger on my RHD car)
Old 03-10-2013, 12:41 PM
Chris_'s Avatar
Chris_ Chris_ is offline
I had exactly same problem after I change new suspension. Check that blinking light under the seat and you will see which sensor is failed. After that put a LOT of wd-40 or something similar penetrating oil on the failed sensor and let it be like that over the night. Before you start taking it off add oil again. Then take it off slowly with some pliers, and remember to use lot of oil.
That is how I get mine off without breaking it. It took time but it is working now after some cleaning.
svx my94 vtd EUDM
-custom Spax coilovers
Old 03-12-2013, 12:50 AM
B 4 You's Avatar
#lolsvx
Well good news! I had forgot, but while I was taking the interior out I unplugged the driver side sensor under the back seat thinking it was one of the connections attached to the "door" panel. Plugged it back in, light went off.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
