Old 01-30-2013, 04:16 AM
Re: help: power steering whine
The P/S pump is very easy to maintain/overhaul. If it was me, I would remove it entirely from the engine, buy a rebuilt kit for it, take it out and overhaul everything.
I have done it once few (a lot actually) years ago and I am looking to redo it again in the future. I will also use THIS ATF inside
Old 01-30-2013, 06:11 AM
Why do you say not the belt? I fought with mine for a year. Belt looked great, belt was tight. Finally I bought new belts and replaced them and what a difference. Unless the belts are new. Don't just go by they are tight and not cracked. Just my 2 cents.
Old 01-30-2013, 08:23 AM
Belts squeak/squeal, not whine. They are two distinct different sounds.
O ring is the only place where air can get sucked into the pump, Any hose is after the pump so any air that may get in would not make it to the pump.
Old 01-30-2013, 04:21 PM
VICSVX's Avatar
VICSVX VICSVX is offline
Never Forget
ok thanks for the other link...dumb me should have read the cap and i would have avoid this mess. guess while its disconnected i'll do the o-ring and take a look at the lines
looks like i know what im doing this weekend
as for the belt....they are a few years old but they dont squeal. it is a whine.
thanks for the replies guys
VICSVX
94 SVX L AWD Conversion Barcelona Red First car and now being restored, 215xxx
Old 01-30-2013, 06:08 PM
I was talking about the stiff steering part.
Old 02-01-2013, 11:10 PM
VICSVX's Avatar
Never Forget
oh ok i gotcha
ill give that a whirl after i change the fluid first. i know for fact that is wrong. if problem persist i will change the belts
thanks
VICSVX
Old 02-02-2013, 11:43 AM
Now that you contaminated the system, u are going to have to bleed the system. Change out as much fluid as you can . Some of that Power Steering fluid is in the rack and hoses.
Old 02-02-2013, 12:36 PM
I would guess that it is the O-ring.
Old 02-13-2013, 03:02 PM
Anyone hear if this squeal got fixed.
