Headlight and turn signal removal
If anyone can help, I'm trying to remove the headlight from my SVX. It looks like I need to remove the turn signal light first, but, so far, I can't figure it out. Thanks in advance.
Re: Headlight and turn signal removal
The turn signals are easy, there is one screw on the top visible with the hood open, after you undo that, they come right. Then you will see the bolts on the side for the headlights. There are bolts on the other side behind the grille as well. In the how-to section I believe there are instructions for removing the grille - follow them closely since the tabs that hold the grille on can be a pain to deal with.
BEHIND GRILLE. 2 bolts BEHIND TURN SIGNAL. 2 bolts .
Wow, you're amazing. Thanks for the fast responses. And great pics. I did have the grille off and removed the bolts and the top screw, but was looking for something else holding the turn light in. The fender is crushed a little just above the turn light so hopefully it will still slide out. I'll try after work in the next couple of days. Thanks again.
Are those pictures with labels from a manual that you have, or did you make them yourself?
Thanks everyone,
After I straightened out the fender tip, the turn signal lamp assy slid right out |
The first photo looks a little odd because I have the clear polycarb headlight shields installed ovr the headlights. .
awesome how-to. much appreciated.
1994 SVX LSi JDM Tailbar and Grill, Clear Corners, 15min-mod, Nevin Blue RSB, G-FORCE SPORT COMP-2 Tires, Phenolic Spacers (Manifold & Throttle Body), SS Brake Lines, Maniac Electric Motors 160A Alternator 2008 Legacy 3.0R |
Did you check the How-To Documents? This how to is under Body.
Well thank you because it clarified everything.
Oops, no I didn't. I don't remember what I used to search the forum but it didn't come up. I'm still learning about the forum so I'll check there next time. Thanks
Are there more details somewhere on how to remove the center grille?
Thread Tools | |
Display Modes | |
