Old 11-16-2012, 08:13 PM
B 4 You's Avatar
B 4 You B 4 You is offline
#lolsvx
Offset Question
I'm wondering what the minimum recommended offset is for our cars. I know ours is +55, but how low can we go? Obviously spacers could increase a low offset to match, but how thick of a spacer is going to cause damage? I can picture it putting strain onto the hubs and bearings. Basically there are some wheels I'm debating about that have like a +05mm offset. Obviously that's a little low. Would spacers to put that out to an acceptable offset destroy the hubs? Do I have any other options that I'm not aware of?
[/discuss]
1992 Pearl White LS
Owned since 2009
175k Miles
2005 WRX manual swap
Rear wheel drive
K-Staff front bumper
Delta Speed side skirts
JDM clear corners
Smallcar grille
Subaru XT steering wheel
Subaru XT shift knob
First bagged SVX in the world
Old 11-16-2012, 08:26 PM
Re: Offset Question
I believe the way it works is spacers decrease the +offset. Wheels with +05 offset would already be sticking out so far that they would not even fit within the fenders. I tried some 18x8 Mustang Cobra rims which were around +20 offset and they stuck out about 2 inches past the fenders.
Old 11-16-2012, 08:36 PM
B 4 You's Avatar
#lolsvx
Re: Offset Question
Am I thinking this backwards? It looks like negative would make it stick out
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 11-16-2012, 08:56 PM
B 4 You's Avatar
#lolsvx
Re: Offset Question
Nevermind. I was thinking it backwards. A zero offset is already outside the fenders. Spacers would make it stick out more. I was thinking 5mm + a 50mm spacer = 55mm offset.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 11-16-2012, 11:31 PM
Re: Offset Question
Changing the offset, moves the center of the wheel off the center of the steering axis. If you go too far, either way, you will get torque steer under acceleration, and brake steering, that moves from side to side on uneven road surfaces.
A little bit won't hurt.
Old 11-17-2012, 05:32 AM
Re: Offset Question
My new are 45 offset and they look great. Thinking 35 would be pushing the envelope.
Old 11-17-2012, 06:11 AM
Subachouli Subachouli is offline
Subaru Parts Guy
Re: Offset Question
Conn, how wide are your wheels?
Width plays a big part in making certain offsets fit. If someone was trying to fit 9" wheels, they might have trouble with the wheel clearing the suspension at the stock +55 offset. On the other hand, as someone mentioned, that 9" wheel might not clear the fender if the offset was too low.
1994 SVX- 5MT, Deltaspeed, Stebro,Work VSXX
1994 Legacy GT
2001 Forester
2002 Impreza WRX
2005 Impreza WRX STI
Need parts?
Old 11-17-2012, 05:55 PM
Re: Offset Question
I have 18" 7.5 wide running 215 tires 55 wall
Old 11-18-2012, 02:24 AM
AlcyoneSVX's Avatar
Alcyone Silver Contributor
Re: Offset Question
My wheels are 17x8 with a +40 offset with 235/45 tires.
It leaves me with about 1/4 inch clearance
of the rear fenders.
ARMANDO
2004 Mazda RX-8
1974 Mazda RX-4
