Old 11-12-2012, 08:38 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Not again! Tick tick tick
I replaced my flexplate about a year ago with the thicker one. I just had my exhaust redone with a new main cat and resonator. I drive on weekends only. But sure enough it's back! The ticking from the engine! It goes away at around 2k RPMs. Please tell me it's not the flexplate again! Could an exhaust leak cause this ticking?
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 11-13-2012, 03:10 PM
dannmarr's Avatar
I work for my SVX
Re: Not again! Tick tick tick
It has been confirmed. It's the flex plate. My mechanic used a small camera to look inside and found the crack. Why did this happen? The last one cracked because the trans locked up and it was the original SVX flexplate (phase 1). This one was the thicker flex plate, phase 2 (I believe the Outback one).
1)Can someone guide me to which flex plate I should buy
2)Is there any necessary steps that need attention for the next install?
3)Anyone know someone who can do the install without breaking my bank?
Thanks!
I noticed that the original flex plate had less holes than the thicker one Does this make a difference?
Subaru SVX for fun
Old 11-13-2012, 03:20 PM
Originally Posted by dannmarr View Post
It has been confirmed. It's the flex plate. My mechanic used a small camera to look inside and found the crack. Why did this happen? The last one cracked because the trans locked up and it was the original SVX flexplate. This one was the thicker flex plate (I believe the Legacy one).
Thanks!
Do you have both alignment pins installed?
Old 11-13-2012, 03:26 PM
dannmarr's Avatar
I work for my SVX
That was a questioned I asked my mechanic. He had an assistant do the job who no longer works there. Are the alignment pins (2) on the left and right side of the housing? We noticed the holes but could not see inside. Are the pins visible or are they deep inside those holes?
Subaru SVX for fun
Old 11-13-2012, 03:38 PM
The alignment pins are on either side of the bellhousing and there are 2 of them. Sometimes they stay in the trans side, sometimes the engine side, pretty randomly when you take them apart. I'm not sure whether you could look at it from the right angle to visually check whether they're there. They are pretty important. When the engine and trans are separated while replacing the flex plate, make sure sure they are both present.
Old 11-13-2012, 06:15 PM
The webbing on the back of the engine block where the alignment pins go is about 0.55" thick.
The webbing on the transmission bell housing where the alignment pins go is just under 0.40" thick.
The alignment pins are about 0.867" long.
So, if the pin is installed, you SHOULD be able to see it from the back.
But, like icing said, just make sure that the pins are installed the next time.
Old 11-13-2012, 09:16 PM
dannmarr's Avatar
I work for my SVX
Thanks guys! Honestly, I did not see any pins in those holes. They seemed empty. I might have to bite the bullet and bring it to a trans shop this time.
Would the flex plate crack because of these missing? Anyone have a photo of how it should look with them in?
Subaru SVX for fun
Old 11-13-2012, 09:21 PM
If you probe the hole with something, Bic pen for example, see how deep the probe can enter.
Gee, someone familiar with SVXi near PA.
Hmmmmmm.
Old 11-13-2012, 11:09 PM
Hmmmmmm.
Your'e about the same distance as me...
I make it out to the Scranton/Wilkes Barre area quite often lately, but I'm usually always pretty busy.
Old 11-14-2012, 05:18 AM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
[/COLOR]
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 11-14-2012, 08:02 AM
Hmmmmmm.
I've used a tool like the one on the right to determine if I'm pulling a trans I just installed.
Old 11-14-2012, 03:06 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
You've pulled a tranny?
Old 11-14-2012, 04:49 PM
dannmarr's Avatar
I work for my SVX
I spoke to my mechanic and he believes they were put back in but they probably fell out! I don't trust mechanics that don't admit their mistakes. I might as well pay extra and have the whole Trans checked at a Trans shop.
Subaru SVX for fun
Old 11-14-2012, 06:42 PM
it's impossible for them to "fall out"
Old 11-14-2012, 07:29 PM
What He^ said!
They have to be driven in with a hammer!
