Really can use some help here
ok first, my car has been shaking/wobbling at high speeds, more then just an off balanced tire, and i think it actually gets a little worse when i let off the gass at those speeds. two things i know of for sure that i need, my driver cv acxle is clicking so its needing to be replaced, and something just blew up essentially yesterday and threw fluid every where, assuming it was my ps pumnp or rack seeing as the ps just went out. But the wobble is pretty intense and am in need of some assistance to figure out what it is.
Re: Really can use some help here
Sounds like a prop shaft, either the centre bearing or one of the CV joints.
Can you feel it through the car more than the steering wheel?
11/94 SVX Alcyone, Mica Black, VL Spec 4WS, 71K Miles, 1 owner from new & was part of a private car collection in Japan. Nissan R34 Skyline Stagea 91 Lotus Elan SE Turbo 1966 MGB Roadster, Tarten Red, Wire Wheels, Leather, 23K miles from new You can tell the men from the boys from the speed of their toys. |
It could be the axle. Since you know that is bad anyway, replace it and see if that solves the vibration.
i can feel it in both the wheel and the car, probably say the car a bit more though, but the wheel will shake alot with the car
Have you checked your ball joints and tie rod ends?
Have you had the wheels balanced, might be as simple as you have lost a weight and at the same time they can see if you have a serious problem with an out of shape or ballooning tyre.
