Old 09-13-2012, 07:45 AM
SVX92-97's Avatar
SVX92-97 SVX92-97 is offline
installing stock spoiler
Im curious to know when installing the stock spoiler if any type of sealent or calking should be used to prevent leaking into the trunk. I was told by another member to use 3M Strip Calk around the holes in the trunk, but couldnt find any at the local Advance Auto store, so I just used plumbers thread tape. There was nothing there when I removed the spoiler.
1995 POLO LSI 76K MILES SOLD
Old 09-13-2012, 08:03 AM
Re: installing stock spoiler
The mounting for the stock spoiler is outside of the seal in the trunk area, so no sealant is required
Old 09-13-2012, 09:14 AM
kwren's Avatar
kwren kwren is offline
mine all have seals...
Keith
Old 09-13-2012, 09:24 AM
The gasket that surrounds the bolt holes also acts as an insulator to keep the fiberglass spoiler from contacting the trunk lid directly, allowing for a snug fit without rattling or damage to either. Fills in any irregularities or gaps between the two surfaces
It also keeps grit and dirt from getting under the spoiler.
The spoiler does have a foam gasket, but it's more to protect the trunk paint than to stop water passage. As Huck said, the spoiler holes are outside the trunk seal, so any water that gets through just drains back out.
