Old 01-31-2011, 02:46 PM
Will Will is offline
Re: Salutations - need help with starting problem
Fuel pump was replaced today. I get her back tomorrow a.m.! I think Im going to go ahead and red sea foam next. Unless someone can give me reason not too? I have never used the stuff before. Also does anyone know where I can get a quick change shift kit? Harvey? Svxpartscentral had one on ebay last week, but I emailed the guy and he said they were no longer available, at all.
Old 01-31-2011, 06:34 PM
immortal_suby's Avatar
Thread Killah
The quick change is temporarily not available due to a part shortage. You might be able to find one that someone has not yet installed. Or you could contact ECUTune / longassname for a modified TCU.
Locker Link
2015 BRZ Limited 6MT
Old 02-01-2011, 05:54 PM
Well I'm back on the saddle folks. I drove this thing like I stole it today! Getting some vibrations at high speed though. Probably from sitting around for a month. I will have the tires balanced and rotated in the next few days. Nice to report closure..........For Now.
Old 02-05-2011, 04:26 PM
Angry Re: Salutations - need help with starting problem
Car has been running fine all week, then I stop to get gas today and when I try to crank it stalls out every time. After about ten minutes of this it finally cranks and runs fine. Run several places, stopping and restarting fine. Get back home and the car sits for an hr or two and now the same thing, stalling out immediately. Keep in mind fp, fuel filter and new strainer were just put in. Suggetions please!!
Old 02-05-2011, 06:02 PM
Could the fuel pump relay be the culprit here? If so, why would replacing the fuel pump illuminate the no start issue for the past 5 days?
Old 02-08-2011, 01:57 PM
I had an electrical problem with some wiring which was pump related. All I can say is I wish I lived closer to WV!
Old 02-08-2011, 03:02 PM
That type of problem can be from an leaking injector that is leaking down the rail pressure when it is stopped. When you go to start it, you have to turn it over long enough to clear the fuel out before it will start.
Old 02-08-2011, 04:00 PM
Invisible avatar
Question Re: Salutations - need help with starting problem
Have we brought up the infamous MAF yet?
Symptoms sound familiar.
Ron.
'96 Grand Caravan - 240K
'01 Miata SE - 79K
