could a maf senor not allow my svx to idle
My 96 Svx will not idle at low Rome could it be the mass air flow sensor
Re: could a maf senor not allow my svx to idle
the maf is a common problem for idle and stall problems at low rpm, another thing to check is vacuum leaks. you can try unplugging the maf to see if the problem changes, a lot of the time you can get away with just cleaning and re-soldering the maf sensor, there is a good document in the how to section.
I put modified my intake and once in a while the piping comes out of the coupler, problem I plan on fixing just isnt enough of a worry to me at the moment, when it does the engine dies, right now. You can restart but it dies immediately soon as the ecm sees there is no air flow.
"You can try unplugging the maf to see if the problem changes".
It won't run without the MAF connected, that's for sure. |
Some other possibilities include but are not limited to: Bad AACV Misfiring cylinder(s) Vacuum leak EGR valve stuck open Crappy gas Rat living in your airbox Just a bad dream you are having, you'll wake soon. |
Fixed your post:
"Some other possibilities include but are not limited to: Bad Idle Air Control Valve Misfiring cylinder(s) Vacuum leak EGR valve stuck open Crappy gas Rat living in your airbox Just a bad dream you are having, you'll wake soon." Glenn
"The only thing necessary for the triumph of evil is for good men to do nothing" Aaron Burke 1993 25th Anniversary Edition #63 of 301. R.I.P. Rojo 7/24/2008 She saved my life! 1997 Ebony Mica Pearl LSI. BLACKBERRY 1998 5-Spd Legacy GT Wagon in Glacier White: NUBURU 2005 Cadillac STS in Sandstorm Metallic: STORMY Veteran and farthest traveler of 1st SoCal2MuseumsMeet2010. http://www.subaru-svx.net/photos/user.php?RojoRocket |
You should be able to start the engine with the MAF disconnected. When the ECU detects no MAF signal, it tries to guess the airflow based on RPM and Throttle position. It works on my car, I've tried it.
Subaru ECU and TCU Website 1992 Alcyone SVX Version L 1992 Alcyone SVX Version L 1994 Alcyone SVX S40-II 2004 Subaru Legacy 2.5 SE Sports Tourer 1996 Subaru Legacy 2.2 GX Wagon 1988 Subaru Justy J12 SL-II |
As b3lha said, it should run without the MAF sensor connected. In fact, when I had a cam sensor issue, with the MAF connected (was thought to be causing issues based on symptoms) it wouldn't run well, bog and die if the idle dropped too low as well as not rev above 2500 RPM in gear or not in gear. MAF unplugged, revved just fine, drove fine, and did not die. Which led us to think the MAF was bad even more until a different MAF had same symptoms and then we pulled out the Select Monitor.
??? Actually either a bad Aux Air Control Valve or bad Bypass Air Control Valve could do this..... our car doesnt have an "Idle air control valve"
Glenn
Thread Tools | |
Display Modes | |
