Old 10-09-2010, 01:41 PM
Manarius's Avatar
Manarius Manarius is offline
Headlight Restoration (warning 56k - heavy pics)
Main Album Link: http://www.facebook.com/album.php?ai...&id=1479900008
I chose to clean up my headlights today. My uncle gave me a 3M kit for Christmas, so after I purchased some clear coat and a nice day came up, I went to town. The kit gives you a couple 500 grit pads, a couple 800 grit pads, a 3000 grit pad, a foam thing for polishing/restoration (and some restoration polish), and an adapter to fit your 1200-1400RPM drill. I was committed to clear coating, so I taped and newspaper'd the crap out of the front of my car and did not use the foam thing/polish. Between each grit pad, I wiped down the headlights with a wet rag. Only the 3000grit called for wet sanding (very light wet; just a spray bottle). The headlights are pretty beat themselves so no amount of sanding is going to make them perfect, but I think they're much better now than they were before.
Total time: I started around 12:15 and started with clear coat at 1:45. It says 15 minutes per lamp; I guess I'm a little slow.
Here's the kit:
Here's the clear coat I got at Wal-Mart:
Here's what they look like before:
Here's what the driver's side light looked like after I took the 500grit to it:
Here's what it looked like after I took the 800grit to it:
Here's what it looked like after I took the 3000grit to it:
Here's what it looked like after 2 coats with the clear coat. I was going to do three, but it started to run so I decided that was enough:
And the left side light with the lights on:
-Jason
-Obi Wan Kenobi
Old 10-09-2010, 02:52 PM
Huskymaniac's Avatar
Uses the ignore feature
Re: Headlight Restoration (warning 56k - heavy pics)
I was looking at that very kit yesterday. What is your verdict on it?
Does anyone have alternative products they would recommend?
Tony
Old 10-09-2010, 03:53 PM
Instead of buying the kit I did mine with 1000grit, 1500grit, and 2000grit wet sandpaper from an autopart store. For polish I used some 3m plastic polish we had at work.
See Post #33 in this thread for pics of it:
http://www.subaru-svx.net/forum/showthread.php?t=54507
First time I did my lights I used "Mothers mag and aluminum polish" instead of sandpaper and polish. It worked ok for taking most of the yellow off. '
Pics here:
http://www.subaru-svx.net/forum/show...2&postcount=12
Old 10-09-2010, 04:43 PM
Cam Cam is offline
I have mentioned it before but I did my tail lights using a micro mesh kit. Google it. Fantastic stuff, i highly recommend.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 10-09-2010, 05:41 PM
The headlights are glass and the taillights are plastic, correct? Or are the headlights plastic too? They feel like glass.
Tony
Old 10-09-2010, 05:48 PM
No, unfortunately they are both plastic.
Old 10-10-2010, 05:19 AM
Alex-svx's Avatar
Alex-svx Alex-svx is offline
Its looks verry good. But i have a little qvestion. What are you useing this for? Before or after?
Alexander (Norway)
My subarus:
1992 Svx LSI 5-MT(3.54)
1998 Legacy BG 2.5L GX
Old 10-10-2010, 05:30 AM
Manarius's Avatar
I used this after I did the process of 500, 800, and 3000 grit sanding.
I think if you're a good rattle can sprayer then you can get one three coats without it running. I'm not very experienced, so after 2 it started to run a little.
-Jason
-Obi Wan Kenobi
