Old 05-15-2010, 02:13 PM
How to Correctly Remove and Put Back the ABS Unit
Hey guys,
Thought I would ask this question... anyone knows the right answer?
I want to do that the correct way without messing up the entire system.
Thanks
Old 05-18-2010, 01:01 AM
Re: How to Correctly Remove and Put Back the ABS Unit
No one did that? Anyone?
Old 05-19-2010, 01:19 AM
Awox Awox is offline
I've done it a couple times, but not correctly.
Old 05-19-2010, 01:36 AM
lol what do you mean by that?
Old 05-19-2010, 05:10 AM
His answer is almost as clear as your question
Old 05-19-2010, 05:22 AM
You find my question that complicated?
I am no expert in ABS units, but we dealt with ABS check light in our old Merc before we sold it. We took it to Bosch service centres and they were able to fix it.
For the SVX, I want to remove the ABS unit to paint the engine bay and put it back without having issues with it afterwards, check light, operational, etc...
I just want someone to guide me through the steps that should be taken to correctly do that.
Old 05-19-2010, 05:42 AM
Not complicated just unclear. There are many different parts of the ABS system spread through out the car. Now I know what part of the system you want to remove and why
- Save your self the headache and drain the brake system using the bleeders on the brakes.
- Mark and then undo the fittings from the pump. Probably best to start off using a flare wrench to start with rather than rounding off the fittings.
- Put a bag over the fittings if they're going to stay in the bay, this will keep paint from contaminating the lines and keep any residual brake fluid from dripping on your new paint.
- When you reassemble, first use the bleeder nipples on the pump itself to get fluid to the pump, then use the bleeders on the calipers to completely bleed the line.
Old 05-19-2010, 06:12 AM
Dave, thank you for the explanation. One thing I didn't quite get, the last point. How do I use the bleeder nipples on the pump to get fluid to the pump? Shall I fill the nipples themselves?
Old 05-19-2010, 06:51 AM
The same way you deal with bleeding at the calipers.
The only complication is getting brake fluid on your new paint. You can either use a hose and a second person to work the brake pedal, or a vacuum bleeder to suck the air out.
Old 05-19-2010, 07:19 AM
I will cover the area with cellophane all the way till the subframe.
So basically I reconnect the lines to the pump, fill brake fluid, bleed the pump first, then bleed the calipers...
Thanks Dave!
Now after that, are you sure I won't be running into any electrical/check ABS bull sheet?
Old 05-19-2010, 08:06 AM
MadMaxSvx's Avatar
MadMaxSvx MadMaxSvx is offline
Thanks Dave!
No electrical B/S if you reconnect everything back properly, in this case try to reconnect everything before turning on the ignition again.
95´ Subaru SVX EURO
85' Mercedes 190 2.3-16
86' Mercedes 190E
70' Olds Toronado
98' Renault Chamade
82' Honda Prelude
79' Honda Accord awaiting restomod.
69' Mustang Hardtop
67' Jeep Ford Willys awaiting restoration.
67' IKA Torino Coupe
74' Renault Torino Coupe
Old 05-19-2010, 08:18 AM
I thought it might be the same as the Airbag thing... or maybe a connection between unit and sensors, that's all.
Old 05-22-2010, 08:54 PM
kwren's Avatar
kwren kwren is offline
Might do a test first to determine if the brake fluid eats through your cellophane... If it can eat the paint, possibly can eat the cellophane
A word to the wise...
Keith
Old 05-22-2010, 11:18 PM
Will do, thanks for the tip
