Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Engine Management
Old 07-09-2009, 12:28 PM
poweredx2 poweredx2 is offline
Airflow meter mod
I've noticed my svx has been running rough.My wires at the connector at the afm are breaking from age,heat,engineflex etc.I have a few old nissan meters here with connectors but they are different so we think.If you remove the base connector from the afm,yes the one with 4 small screws,you can wiggle it out and replace the svx base connector with the one from a z32 nissan.After that just splice the nissan connector onto the svx harness and you are back action.A bit of caution I took was to remove the top from the svx afm to visually see that the nissan prongs were aligned with the prongs inside of the svx meter board.My cars drive great.One other thing if you have a damage airflow meter housing don't trash the entire meter just swap the meter board to a svx or nissan unit or vice versa,the meterboard is secured by4screws.I trashed 6 z32 meters because of minor damages
