Go Back   The Subaru SVX World Network > SVX Main Forums > Upcoming Meets
Old 12-14-2008, 05:29 PM
Re: Atco Dragway 12/14/08
Originally Posted by Phast SVX View Post
overboost is a typical symptom of an undersized impeller... like you said keep the boost down and tune the **** out of it. again congrats
Didn't even think about that... I already knew the charge was getting too hot... Might be time for some Methanol injection pre-blower
Old 12-14-2008, 05:35 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
I can only imagine the power you are putting down.
My friend's 400hp 6.0 liter GTO weighed in around 3800 pounds and ran a 13.33 at 106.
You must be pushing 350 hp or more
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 12-14-2008, 05:53 PM
Because I'm still waiting...
Old 12-14-2008, 05:58 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
I'd have thought the rear tires would look "flatter" with only 20psi in them
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 12-14-2008, 06:02 PM
-Bill
Not with those stiff sidewalls... Those tires are not exactly "drag racing" appropriate
Old 12-14-2008, 06:08 PM
http://www.youtube.com/watch?v=wMeDMPCpoD0
Here it is.
Old 12-14-2008, 06:11 PM
nm its worky
tom
Old 12-14-2008, 06:15 PM
lol@ eric...
Old 12-14-2008, 06:21 PM
Originally Posted by TomsSVX View Post
lol@ eric...
That was my first thought, well, right after "holy **** that was quick!"
Old 12-14-2008, 06:30 PM
SVXRide's Avatar
How about that, no flames coming out of the tailpipes!
-Bill
Old 12-14-2008, 07:13 PM
immortal_suby's Avatar
Thread Killah
that ****ing rules! congratulations on getting into the 12's
Locker Link
2015 BRZ Limited 6MT
Old 12-14-2008, 07:18 PM
Thanks but it is only by the skin of my teeth
I hope to have it consistently running 12.5-12.7 w/ a good tune on it next spring, its getting time to put it away for the winter.
Old 12-14-2008, 08:23 PM
Sov13t's Avatar
Sov13t Sov13t is offline
Was a lot of fun to drag for the first time.
Granted my results are at best sub-par, I was happy with the improvements and lessons that I learned during the 3 runs that we had.
I kept trying to concentrate on specific aspects... like for example paying attention to how I launch... and then I would be like ... "oh... @&^!# SHIFT SHIFT SHIFT!" then another run I would try to pay attention to shifting... and so on...
Code:
Run #1
Hydra EMS, spun tires at launch for a bit...
R/T  ...   .276
60'  ...  3.077
330  ...  7.677
1/8  ... 11.522
MPH  ... 66.45
1000 ... 14.731
1/4  ... 17.362
MPH  ... 86.75
Code:
Run #2
Hydra EMS, 3000 RPM launch
R/T  ...   .177
60'  ...  2.326
330  ...  6.559
1/8  ... 10.013
MPH  ... 69.69
1000 ... 12.984
1/4  ... 15.500
MPH  ... 88.52
Code:
Run #3
Stock ECU, 3000 RPM launch
R/T  ...   .215
60'  ...  2.383
330  ...  7.028
1/8  ... 10.756
MPH  ... 65.92
1000 ... 13.924
1/4  ... 16.652
MPH  ... 83.04
Until next time
Perhaps in a totally different car?
Thanks Tom, Mike and Eric for having me over yet another time
-Sov13t.
Subaru SVX 94' Laguna Blue - 8.5 C/R Built Motor, 6spd
Old 12-15-2008, 06:12 AM
shotgunslade's Avatar
Congratulations, Tom.
The issue with the pressure rising at high rpms is not surprising, but it isn't that important unless your intake manifold leaks. Your Whipple is what is called a positive displacement device, in that it grabs a fixed volume of intake air and compresses it to a much smaller fixed volume. The total volume of air it moves is linear with rotational speed, no matter what the exit pressure.
This is in contrast to a centrifugal compressor, as used for turbochargers, which develop pressure and thus ability to create flow with the square of the rotational speed. However, the airflow downstream of your supercharger may become very turbulent at high rpms, creating significant pressure drop. Unless your intake manifold is leaking, that amount of air that is getting into the engine at a specific rpm is fixed, it just may take more pressure to force it through the intake pathway. The only downside of this pressure drop is that it takes more power to drive the blower.
That is why intercoolers aren't nearly so advantageous for a positive displacement device as they are for a centrifugal device, such as OT's supercharger. Because flow through a centrifugal compressor is dependent on exit pressure, cooling the air heated by compression in the supercharger will reduce the exit pressure thus increasing flow. With the Whipple, the exit pressure has no effect on flow, just on compressor drive power.
On the other hand, pressure drop on the intake side of the compressor at high rpms is very important, because air density will be reduced by inlet pressure drop. So, your fixed volume of air that the compressor is moving at any specific rpm will have less mass if there is high intake pressure drop on the intake than if there is low intake pressure drop.
So, bang for the buck with a positive displacement compressor is to reduce pressure drop on the intake side of the compressor. The pressure drop between the compressor and the cylinder will have little impact on engine power output, except tthrough the parasitic power to drive the compressor.
There will be a pop quiz. Tom has already been given a bye on the exam and has an A+ for the course. The rest of you, study up.
Old 12-15-2008, 07:27 AM
sicksubie's Avatar
I cannot wait to get my car straightened out and this installed. If Tom is running 12.99 on a base tune on a stock block, what will I be at with a built motor, the bigger pulley, methanol injection, and twin intakes
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
