Old 10-19-2008, 07:04 PM
Hop Hop is offline
Classic SVX
ABS light
My ABS light came on tonight. Does this come on because of a low fluid level? What else would cause this indicator light to come on?
I did a search and can't believe that nothing came up on this.
Old 10-19-2008, 07:56 PM
Re: ABS light
Lots of possibilities. A bad wheel speed sensor, cracked (badly) tone ring, problem with the ABS pump, problem with the ABS computer... When you brake, does the ABS kick in prematurely?
You might as well check the fluid, it's the easiest and cheapest possible solution.
