Trans hard line problem
Ok so I got the new FWD trans in the car, put fluid in there, etc. etc. Turned on the car and fluid spewed out of one of the trans hard lines. One of the hardlines was split. So I grabbed the one off of the old trans that came out of the car and they had two different fittings. The new trans that I put in the car has a flange fitting..whereas the fitting on the old (bad) trans is a banjo fitting (which OT said are the same fittings that are on all of the trans that he has and its the same fitting that are on all of my other trans too)...
Here's a pic of the two different fittings. The cut off piece is what was on the new FWD trans that is in the car. The complete line is the banjo fitting that should be on the car. I figured that maybe it would work anyway. BUT, this trans (the good one in the car) the setup is completely different and was professionally manufactured. Here's a picture of the setup that's in the good trans. As you can see there is a piece in the hole in the trans rather than the ball that you usually see for the banjo setup. (sorry for the sucky pictures I could only use the cell phone.) This is the ball setup for the banjo setting... So my question is this: Where can I find a hard line like the one that I should have in the car? I was going to check my local Subaru (but mostly Ford) dealership to see if they have something like it. Does someone have one lying around?
Rebecca 92 Claret SVX LS-L (180k) 09/91 #5,732 06 Suzuki Boulevard M50 7k 68 Cadillac Coupe DeVille (70k) Storage/hibernation for now. Past SVXs: 94 SVX Emerald Pearl FWD (Sold) 96 SVX Bourdeaux LSi (Sold) 92 Pearl SVX LSL "Stay Puft" 5MT (140k) #148 (RIP) 95 Brilliant Red SVX LS (162k) 12/94 #564 "Killer Tomato" (RIP) |
I'm pretty sure I've got one of those....
Butttt, currently it's doing it's job in my car Sorryhehe
bLAh
I believe it is just a flare... might be able to reproduce it... I will look at all the transmission here to see if there is another one... Sorry for the troubles with that
Tom |
I have a scrapped FWD trans at home, I'll take a look on Monday to see what fitting it has. But yeah, like YT said, It looks like a standard flare/compression fitting.
If you can't find it at an auto parts place, try a shop that makes hydraulic hoses.
If you guys have one let me know. I will check around after Tuesday. Thanks!
It's okay. Sh!t happens. I'm just thankful to have a working FWD trans. Yes it works!
Hey Rebecca, if you can, give me the thread on that compresson fitting and I will try and make up up for ya... Oh, BTW I just got a FWD 5mt for free if you wanna swap that in instead
Tom |
Being a stanard single flare fitting, it's not hard to make. IIRC most auto parts stores carry flared tubing, with the fittings attached. They also carry fittings, and flaring tools.
Worst case, you could use a piece of ruber line on what's left, to splice the hard line back together. This will get you on the road. I agree though, that it needs fixed properly.
[SIGPIC]http://www.subaru-svx.net/forum/image.php?type=sigpic&userid=5569&dateline=1207440 507[/SIGPIC] Naught but by the grace of God "42" Current Stable By Age:'89 Subaru XT6 Silver "Audrey" as in Hepburn '96 SVX LSi #767Brilliant Red "Lil Red" Now on the front burner. Looking for a totalled, but running parts car. |
Thread Tools | |
Display Modes | |
