Old 11-09-2007, 09:49 AM
shotgunslade's Avatar
Lime Rock Again
Thought my season was over, but got a call from NASA NE two weeks ago saying that a spot had opened up in HPDE 3 at Lime Rock on November 3. I guess that means I'm now officially promoted to HPDE 3. HPDE 3 sessions have extended passing zones, and require no instructor sign-off to solo. I also can attend the open track sessions, that have no instructors and have no sessions, just unlimited track access for the entire day.
Here is a track map of Lime Rock:
It was a good day if very cold. I really worked on finding speed, especially in the No Name Straight, the Uphill, the Diving Turn also known as the Downhill. These last two turns are really a test of cojones. You can't believe how fast you can take these turns. Finding the limit is a real test of courage, because the limit is so high and the penalty for exceeding the limit involves an intimate association with the Armco. Here is a shot of me entering the uphill at the end of No Name. Because it is an uphill, the car is really compressed and there is a lot of grip. The only caveat is to have the car straight when you crest the top of the hill onto the straight right after the turn. If you are still turning, you have a good chance of spinning when the car gets light. With work, I'm hitting about 100mph at the end of No Name. Just getting to the point that I have to shift, because I'm hitting about 7200 rpm in third.
The other speed opporunity is through the West Bend, the Downhill and onto the main straight. With courage screwed up, I'm able to take the Downhill at maybe 80-85 mph. This translates into about 110 at the end of the main straight. Here is a shot of the West Bend. I passed the Miata on the main straight immediately after this shot:
I'm still having some problems in the Big Bend. The whole sequence through the Big Bend, the Left Hander and the Esses is complicated. The Left Hander is really a throw-away. It should be driven to set up to maximize early throttle on through the right hander onto No-Name. So, setting up the Esses has to start all the way back at the turn-in to Big Bend. Pretty complicated.
So my track tires are now in the basement for the winter. It was a very good year.
Old 11-09-2007, 02:01 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Dan,
Sounds like you ended the season on a good note
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 11-09-2007, 02:27 PM
Bill:
Yes, it did. No off's in the last 6 track days. Car ran well the last part of the year. New tires and new alignment work very well. Starting to pass people again. Five months until first track day of 2008 at Lime Rock, again. Hope you get more track time in the new year. When you do, keep the shiney side up.
Dan
Old 11-09-2007, 02:56 PM
wawazat??'s Avatar
Yeah, I'm still around
Very nice Dan, very nice
Todd
Down to none
Old 11-09-2007, 03:32 PM
sicksubie's Avatar
I really want to do this next year....
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 11-10-2007, 07:35 AM
Sicksubie:
Sports Car Driving Association (SCDA) does track days at New Hampshire International. NASCAR track plus infield road. I've never driven there so I don't know anything about the track. Lots of groups do events at Lime Rock. SCDA, NASA NE (PDA Driving School), etc. I would recommend that you go with a group that provides instructors. Cost at Lime Rock Park per day is about $250-275. A few things to do before you go out. Use a high performance DOT 4 brake fluid. Get good brake pads, especially front. I really, really like Axxis Ultimates. Would suggest you install speed bleeders on the calipers. I bleed my brakes before every track day. The speed bleeders make it a one man 15 minute operation. I would add water wetter to your radiator fluid. Your signautre doesn't say what you have done to springs and shocks, but a GC/Koni set-up handles very very differently from the stock set-up. Finally, tires. The SVX is a heavy car, so, a good set of Ultimate Performance Summer Dry tires, BFG G-Force KDW's, Bridgestone RE01-R's, Yoko Advan Neova AD07's , or Falken Azeni's would be a big help.
Dan
Old 11-10-2007, 12:24 PM
sicksubie's Avatar
I have water wetter already in, those are the pads that I have, I am getting the Koni/GC set up ths winter, and I am running 225/45/17 RE070's currently.
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 11-11-2007, 08:30 AM
Sounds like you are good to go. Look forward to seeing you out there.
