Old 04-18-2004, 02:49 PM
SubaSteevo's Avatar
No longer blue member
Amplifier Overheating
My amplifier keeps over heating. It works for about 20 mins - an hour and then shuts down. The amp is mounted on the back of the rear seat, which I usually keep up. The RCA cables were getting crushed when I folded the seat up, so I moved the amp and now they have plenty of room but its still overheating. It's a 300W Jensen amp running a 12" Pioneer sub. What are some causes of overheating?
-Steve
01' MSM Lexus IS300
Old 04-18-2004, 02:59 PM
immortal_suby's Avatar
Thread Killah
Re: Amplifier Overheating
Locker Link
2015 BRZ Limited 6MT
Old 04-18-2004, 03:56 PM
Porter
Upgrade to higher current power and ground wiring. Ensure that your ground wire is as large or larger than your power wire. Ensure that it is grounded directly to a primary part of the car's structure, and that bare metal is being contacted fully.
Four gauge wire should be sufficient for your purposes, don't go any smaller than that if you can help it.
If you already have 4 gauge power cable, then I'm barking up a wrong tree and you should tell me so.
Oh... and I almost forgot, if the amp has heat sink vanes, make sure they are oriented vertically to help the convection process.
Old 04-18-2004, 04:15 PM
SubaSteevo's Avatar
Re: Re: Amplifier Overheating
Originally posted by immortal_suby
-Steve
01' MSM Lexus IS300
Old 04-18-2004, 04:19 PM
SubaSteevo's Avatar
I bought one of those amp installation kits when I installed it, I think the power wire is 4 ga and the ground is 6 ga. I'll try using the leftover power wire as the ground instead. I don't understand why the size of the wire would increase/reduce heat, can you explain? The weird thing is when it was hooked up using the high level imputs it would rarely overheat, but with the RCA imputs it overheats much more often, could there be any reason for this? Thanks Porter!
-Steve
01' MSM Lexus IS300
Old 04-18-2004, 04:22 PM
Porter
That's odd.... sounds like perhaps you have the gain cranked up too far on it. Try turning down the gain and turning up the input sensitivity, if you have such a control. (It is a Jensen after all! )
But ya, upgrade that ground.
Old 04-18-2004, 07:08 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Sometimes if you have the amp mounted on an angle that wont allow proper cooling it will overheat as well.
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 04-23-2004, 12:08 AM
KAMzilla77's Avatar
KAMzilla77 KAMzilla77 is offline
Send a message via AIM to KAMzilla77
What Radio are you running?? (Brand/Model #)
If your radio has high volt output and your amp gain is too high you amp will most definatley overheat and shut off. Jensen Amplifiers are not built to withstand high voltage signals. Which would explain why you didn't have a problem when you ran speaker inputs.
Old 04-23-2004, 09:18 AM
SubaSteevo's Avatar
This is my headunit, Pioneer DEH-5
http://cgi.ebay.com/ws/eBayISAPI.dll...092794281&rd=1
2.2V pre-amps, not high
...oh well if all goes well I should be getting my friend's 500W Lightning Audio amp for $10 when I put in his new system.
-Steve
01' MSM Lexus IS300
