Old 02-20-2004, 09:46 PM
corey_256
Angry light problems
i'm still having some sort of electrical problem with my car. i just put in a new alternator and that cured the problem with the defrosters and the stereo but the lights in the insurment cluster still come on when i turn the wheel which also gets really hard to turn, they also come on when i hit the brakes really hard. not all the lights come on only the steering, stop lamp, brake, abs, and the charging light. the ps fluid is full and there are no signs of leaks coming from it. also, the white plasic box way up high underneath the dash, what is it? cause mine has electrical tape wrapped around it and it really looks like someones been into it.
Old 02-20-2004, 10:09 PM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
Re: light problems
Check the belt that connects all the stuff at the front. Most likely it's loose from the sound of it.
Lwin M. Maung (Member # 147)
Current SVX: NONE
Old 02-21-2004, 01:07 PM
corey_256
do you know what the tension should be, i have a gauge but i don't know what the tension is.
Old 02-21-2004, 10:37 PM
corey_256
well i discovered that part of my problem is a shot crank pulley. anyone know where i can get a new one?
