Old 02-03-2004, 12:20 PM
92pearlbob
Red face transmission noise. . .
I just got my svx back from the shop and it had the transmission rebuilt and i'm curious if i should bring it back for them to look at it again. when i'm on the gas and i take my foot off the gas theres a clunk sound right where the transmission is. a couple times the shifter rattled while making the sound. should i be worried or is this normal.
Old 02-03-2004, 07:36 PM
rperry03
They could have left the bolts loose/or not in from the exhaust hanger, same with the rear trans mounts or the little tab on top of the rear housing (could be sticking up hitting the floor board)
Old 02-03-2004, 08:37 PM
92pearlbob
it had made this noise before i got it fixed but much worse, what happened before was the front differential exploded. can this be the front differencial "clunking" into gear or something??
Old 02-04-2004, 05:39 PM
rperry03
Check all your mounts first, including engine. Look for breaks and nuts and bolts missing.
Old 02-04-2004, 08:32 PM
Will it make the noise when shifting into reverse (or initially accelerating in reverse).
It sounds like the noise caused by a worn tranny mount.
Old 02-05-2004, 03:32 PM
92pearlbob
reverse
yeah, when i put it in reverse the same loud "clunk" happens.
Old 02-05-2004, 05:09 PM
Mr. Pockets's Avatar
Moderator
It sounds to me like a bad tranny mount. If that's not it, then I'd start looking for lash in the driveline somewhere.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 02-05-2004, 06:53 PM
CDG's Avatar
CDG CDG is offline
No front plate on My SVX
Send a message via MSN to CDG
the answer is yes, bring it back to them and try to get them to find this problem.
Chris G
92 Pearlie, sold @ ~209k miles. Now owned by Tim.
Current Ride, 1985 Honda Aero 80, stock 3024 klms
