You'd also need the data cartridge.
white leathers, h.i.d, ecutune S/C stage 4, 14 inch 2piece rotors big brake kit., , msd ignition, c/f dash kit, front spoiler,carbon fiber jdm rearc wing,19 inch rims, nos, , aem fuel regulater, koni-gc package, ported cylinder heads, supercharger cams,solid buck and shims,wrx sti intake valve and exhaust valves,& valve springs, gas analizer,water injection, exhaust temp gauge, idiglo gauges, shift kit, , remote start, all automatic windows,2.5 inch true dual exhaust system with crossover, and 2 borla stainless steal muffler,air filter velocity air stack 3inch to 6 for air filtre, group n mounts, momo steering wheel, dyno will happan soon |
Can this device re-program the ECU with user selected perameters? I wanna change some things.
Or can it only reload the various available regional baseline data? or am I even making any sense?
Chris G 92 Pearlie, sold @ ~209k miles. Now owned by Tim. Current Ride, 1985 Honda Aero 80, stock 3024 klms |
The OBD2 vehicles might be reprogrammable using Prodrive ECUtek (we have it here) but I have no '96+ SVX to play and test with. |
OK, that makes sense, I guess my only option would be to program the Cartridge loaded data, which sounds like a job for Lwin
A who-what Chip???
Tell me more!
Just type "Dastek Unichip" in .
Thanks.
It appears there is only one distributor of the Unichip in North AMerica, www.theracersgroup.com. I sent them a message. But after reading the detail I'm not sure the unichip will give me control of the Transmission(TCU)
The Unichip will allow you to tune an SVX motor (with appropriate modifications re: exhaust, intake, headers, cam, ignition, fueling, etc... to about the 350 hp level in naturally aspirated form without cracking the block open. They have a 6 cylinder version that is specified for pre-OBD2 vehicles that supports control of direct ignition systems. |
Thread Tools | |
Display Modes | |
