speedometer stopped working..
Hi ,
My speedometer stopped working and the " Engine Check Light" came on..Does this relate to a speed sensor ? If yes, what causes this problem and how expensive is a vehicle speed sensor for 1992 SVX? Thanks, I. |
Re: speedometer stopped working..
Likely, the speed sensor on the passenger side of the transmission, on the diff housing, has failed. I don't know the cost, someone will probably provide a link for that. Not too difficult to change.
Special Thanks to Our Friends and Sponsors: * http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/ http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston "QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works, '92 Subaru SVX LS-L Claret ORIGINAL OWNER '92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~ '92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143 '92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117 |
Does the power light flash at startup? That's what mine did when the speed sensor failed in my car. Luckily I had an extra one attached to the 6-speed I bought that arrived the week before. I'm told the sensor is super expensive from Subaru. Best to pick one up from a parting out thread.
Thank you very much, guys!
If it's the sensor, you're lucky. If it's the gear that drives the sensor, you're in for a surprise. To check the operation of the drive gear you need to pull the sensor. Insert a flathead screwdriver where the sensor was in the notch for the sensor. Put a mark on the handle and drive a few feet. If it rotates, it's functioning, if not you have to pull the diff to replace the $2 part. The sensor is located right by the diff dipstick. Good luck, I had both go bad and it cost around $500 to repair. A malfunction with this sensor will mess up all kinds of things from your fans to your cruise control, wipers and awd system.
cost me $4100. TH
Kenneth 1997 Subaru SVX LSi "Svetlana" #185 of 640 - 09/1996 - Polo Green Pearl - 34k miles 1992 Subaru SVX LS-L "Everett" #8738 - 01/1992 - Ebony Pearl - 139k miles - 5MT shifty - Sold 07/31/2011 1992 Subaru SVX LS-L "Sven" #1599 - 05/1991 - Claret - 168k miles - Traded 05/11/2005 2023 Subaru Crosstrek Limited CVT - Crystal White Pearl - 2.8k miles 2021 Subaru Forester 2.5i Limited CVT - Horizon Blue Pearl - 17k miles 2023 Volkswagen Jetta S 6MT - Pure White - 2.6k miles 2020 Hyundai Ioniq Limited EV - Ceramic White - 30k miles |
